2018 JLUR ESS Issue
rmcveigh
Ryan
Denver
Hey folks, I have searched and I'm not seeing the answer to my particular issue, so I'm hopeful someone has seen this. I have an early model 2018 JLUR with just under 60k miles. I've replaced the main and auxiliary batteries. Recently, I was driving during rush hour and the auto stop start engaged. When I attempted to start rolling again, everything lit up like a Christmas tree and the Jeep refused to start back up. I ended up having it towed home.
At home, I pulled fuse 42 and disconnected the aux battery negative cable. I wrapped it up and secured it. Unfortunately, in doing so, I ended up frying my N3 fuse so I moved everything to N4 and things fired right up.
Afterwards I started getting some very strange behavior - the jeep electrical system would "turn off" (e.g. panels all went dark) while driving. Obliviously this is a safety concern, and I researched. I had my local dealership apply the flash per the TSB for 2018's. Things seemed great, but just a few days later when I ran out, the Jeep didn't start when I pushed the button and while the system went to "run", the engine didn't start. I cycled it to off, tried again and a full dead instrument panel. I've noticed that if I open the hood, essentially pull on the negative battery cable, it'll show power again and then I can start it. This isn't great.
Any ideas? I do have new fuses in hand (not installed) so I can install them and go back to N3. I had hoped that'd be a backup in case of some future issue, but perhaps that's my issue? I'm at a loss and it isn't sustainable to have the vehicle refusing to start at random moments.
-Ryan
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
Looks like a loose negative battery cable.
rmcveigh
Ryan
Denver
I thought so too - and I've cranked it down tight and confirmed there is no corrosion on the terminal as well.
JerseyJeff
New jersey
2022 jeep wrangler rubicon extreme recon
Other people with this issue have reported it to be the canbus connector behind your glove box. They say it costs about 70 bucks. You can do a search on canbus issues on the forum if you want to read more about it. Hope you get it fixed.
rmcveigh
Ryan
Denver
Thank you! Plenty to research on that one.
rmcveigh
Ryan
Denver
I ended up replacing the green canbus connector. After a short testdrive everything appeared fine. On my very next drive everything went haywire. I was unable to power off or restart the jeep. and I had to disconnect the battery and reconnected it to get it to start again. I suppose what I should do now is replace the white connector. Does this make sense to everyone?
rmcveigh
Ryan
Denver
The saga continues. White canbus replaced, no change. Tazer removed, no change. I'm pretty much at a loss here. Any ideas welcomed.
Bob Burd
Bob
San Jose, CA
www.snwburd.com
Your problem doesn't sound like a CANBUS issue, rather something more basic, electrically. Do you know that your main battery is OK? Have you load tested it?
rmcveigh
Ryan
Denver
I have and it tested good - at AutoZone and O'Reilly's.
