ESS ISSUES 2018 Jeep Wrangler JL
am1978
MD
2018 JLU Sahara Bright White, 2018 JLU Sahara HellaYella
‘Merica
timn1984
Tim
Louisville, KY
Jeep Wrangler Unlimited 2018 JL Sahara,Dodge Journey 2012, Toyota Camry 2015
Yes
ESS Issue: I seem to be having the opposite ESS issue (or should I say ASS???). I got my 2018 JLU Sahara in October 2018, and the ESS was working fine, but now it seems to not work. I came to a stop (gas tank was full), and no engine shut off. Most people would think this may not be a problem, but I got to thinking, could this be a start of a new problem with the electrical system of the jeep?
Sean L
Sean
North Carolina
2018 Jeep Wrangler Sahara, 2017 Honda Accord Sport, 2003 Yamaha V Star 650 Silverado, 2014 Yamaha V Star 1300 Tourer
There's an ESS information display that will tell you the reason ESS is not functioning. Its usually Battery Protection mode when mine isn't activating.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
If you go to screen #6 in the EVIC display it should give you the reason ESS is not working
hanschien
Houston
I'm not sure when mine stopped working but it's always saying that it's charging, even with 40+ minutes of driving. I guess that's a "feature" and not a bug as I used to always disable it every time I start the Jeep.
WranglerMan
Will
Katy Texas
Gas Pipeliner
Mine said charging all the time as well and after the dealer checked it they found the main battery bad, also do you have a programmer installed
hanschien
Houston
No programmer installed and also checked all the fuses, some were a little loose.
WranglerMan
Will
Katy Texas
Gas Pipeliner
I would have your batteries tested, several here have had batteries replaced, they found mine bad even though it started everyday
timn1984
Tim
Louisville, KY
Yes
My ESS display said "Engine too cold" Does the ESS not function when its cold??
Sean L
Sean
North Carolina
To add on to @Rhinebeck01 reply, There is another condition where the outside temperature is too cold and ESS will not function as well. I've only seen "Battery Protection Mode" in below freezing temperatures so I think that's what it displays when the outside temp is too low for ESS.
WranglerMan
Will
Katy Texas
Gas Pipeliner
Here are some things that will prevent ESS from working:
Seat belt, driver door not closed, battery to cold or hot, battery charge is low, steep grade, cabin is heating or cooling, HVAC at max, tranny is not in a forward gear, hood is open, your in 4lo, light pressure on break pedal.
And here are a few that MAY cause it not to work;
Engine temp to high, low fuel , system fault
Tritonman
Keith
Upstate NY
2018 Rubicon JLU
ITS Duty Manager
I'll add to the list of ESS issues. Mine stopped working and my Auto Park ended up being disabled as well. Turns out it was a bad sensor in the door latch so the jeep thinks the door is open and shuts those 2 features down.
timn1984
Tim
Louisville, KY
Yes
OK last time to bring up this issue. My ESS does not work, as posted before and the dash readout says "Engine too cold" I assume it means that when the engine is cold, ESS does not work. I commute about 2 miles daily and do not go much farther that that daily, just some city driving. I haven't been on a trip in a while. So my questions is, does the ESS not work when the engine is cold, but when the engine warms up, say 30 minutes of driving in a cold environment, it will begin to work?? Just trying to get some info before I take my JL in for its first oil change and check of systems.
Smart Stop Start
