ALEX-4LO
Looking for any input or someone who experience anything like this before.
2018 JLUR 3.6 with 66k miles.
For the past a couple of weeks, I notice cold starts would crank slower. I did not think much of it because I really don't use the Jeep much anymore. A couple of days ago I was driving and got an "engine shut off soon", start stop light and battery light message and my display froze and jeep went limp. Luckily, I was close by my house and was able to park quickly, I noticed white residue on the main battery negative terminal, plus copper discoloration, nothing crazy. I remove the battery and aux to get tested at Autozone, main comes back fine - Aux comes back low and gets a free charge. Pick up 5-7 hours later and install. Turn on jeep (in the garage) and same light display and engine shut off soon message comes on.
Battery is an Optima DH6 AGM, only ~8 months old. Aux battery is ~2 years old (Autozone brand). Still in question, why did this battery cause copper discoloration, thinking faulty battery.
I do have a Tazer and use it to bypass the start/stop button.
I now check and see if I can bypass the aux battery completely and just use the main by removing the aux battery and connecting the positive terminal from aux to the positive main terminal, same issue all lights come on. I then remove the negative line on the main battery that feeds the ESS system. I turn on the Jeep, and same message and lights turn on immediately after starting. So, bypassing the aux battery never worked for me. I turn off the engine and turn on to "run" only position and notice the battery is displaying 11.8V
I replaced the N3 fuse array. installed the "charged" aux battery again and made sure all terminals were properly connected to the main battery and aux battery, start the jeep and engine shut off lights come on immediately.
Working theory:
Working theory:
- Replace main battery and aux - all new batteries, I guess...
- Replace IBS sensor and negative battery cable.
- PCR relay is in question. --- sigh
- I attached a photo does the negative cable clamp need replacing?
