PegFundy
- Heather D
- Aug 18, 2018
- Mojave Desert
- 24 JLW, 18 JL
Of course this happens today, crazy day at work so I haven't investigated deeply yet but if anyone could tell me where you think I should start I would really appreciate it.
2018 JLU 66k miles. I've been smelling coolant when exiting the jeep the last 2 times I've driven but levels look fine on dash, no dash lights etc. I opened the hood today & the coolant reservoir is empty, coolant is all over the outside of the reservoir as well as the underside of my hood as if it had exploded. I propped the hood & coolant was actually dripping down the hood & running on to the side of the jeep.
I don't see coolant anywhere else under the hood other than directly above, below, and dripped down from next to the reservoir. I don't see any obvious cracks or leaks on the reservoir but again busy day at work & haven't investigated. I had my oil changed at the dealership about a month ago & they didn't call out any issues. Any ideas where I should start?
Edit: Is that a burn mark on the reservoir? The plastic inside of it seems dimpled as well.
