2018 JL upper rear spring perch failure.....
FulThrotl
Randy
Huntington Beach, CA
2018 JL Rubicon
found this today.
has anyone else experienced this? seems the weld didn't
have good penetration on one side, and tore off. its happened
in the last 4 months since i put a metalcloak lift on the jeep.
3 1/2" lift. everything was fine when we set up the suspension.
the jeeps an overlander, and has a fair bit of weight in it.
that being said, it goes a lot of places, but i don't beat up
my hardware.
this is the right rear corner, looking straight up from behind the
axle. the other side looks pretty good.
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... jee
SH556JL
Steven
Florida/Georgia
21 JLR M6 RIP, 23 JLR M6
Yikes, I wouldn’t count on Jeep fixing that. But doesn’t look like it would be a difficult repair for someone that knows how to weld.
FulThrotl
FulThrotl
Randy
2018 JL Rubicon
it's a 2018 with 114,000 miles on it. i don't expect jeep to do anything,
nor, truth be told would i really trust them to do anything.
i'm just wondering if this is a common failure.
when i first bought it new, there was a lot of weld failures on
JL steering component tabs. i weld pretty good, and one of my
closest friends is a very good certified welder, and we spent a
morning looking at every weld we could see when it was brand new.
this one looked good, and it looked fine when we hung suspension and
stuff off it four months ago. just wondering if anyone else has had this thrill.
SH556JL
Steven
Florida/Georgia
Wow, you really put some miles on it. I have came up on some threads with weld failures, believe a recent one was front lower control arm.
Some of my welds look kinda crappy. But I don’t know much about welding.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
This is a normal failure for what you're describing.
You may want to clean the paint off of the other perch, as well, and do an inspection.
However, this is a very simple fix. Clean it up and re-weld it. Run a double bead with .035" wire and turn the heat up a bit. You'll be good to go.
slowcrawlerZJ
Chad
Oklahoma City
2019 JLUR, 1982 CJ7, 2018 WK
Retired Navy
I've repaired many welds on Jeeps of all models from gapping cracks like what you have to cracks that you barely see any separation . It can be difficult to pin point a failure point while simply looking at them face on unless its something like you have. Meaning its what you cant see behind the weld points of the metals in the crevice. The majority I have run into give way due to normal contaminants (dirt, salt etc) that concentrate on the weld bead area and eventually make it a weak point then add the stress. All that to say is what chevymitchell said. Yes it does happen and it is common on many jeep models especially for folks who go out into the back country and who offroad alot.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Same thing happened to Litebrites Step Child about a year ago. They discover it at 3:50ish into this video...
FulThrotl
FulThrotl
Randy
2018 JL Rubicon
yup. same thing. as time goes on, i'm more and more underwhelmed
with jeeps manufacturing skills. thanks for posting this. their solution
was about what i was gonna do. a piece of 7/8' unistrut is what i was
gonna use.
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
I’m going to put welding a crossmember to this on my list of things to do. Similar to 13:30 in the LB video above.
FulThrotl
FulThrotl
Randy
2018 JL Rubicon
only if you've lost the OEM exhaust.
the light brite folks don't have anything in the way
this is what we did instead. should be fine.
a full weldment, with a gusset.
if this tears loose, i'll box the entire thing in 1/4" plate.
have someone brake me a 2" x 5" x 5' angle, and make a pattern
and plasma cut it, and do a full weldment
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... patch
FulThrotl
FulThrotl
Randy
2018 JL Rubicon
If this is the worse thing that happens to my rig when I get that many miles on it and as much as we wheel it, I’ll be good with that….. nice fix…..
this isn't the worst thing. this is the latest thing.
the worst thing stranded me in utah for four days waiting for fucking FCA to ship a fuel pump.
47Jeepster
Tom
Queen Creek, Arizona
2025 JLUR X ... 2023 JLUR Diesel ... 2018 GC Summit
Add one more example to the cracked frame perch list. I have a June 2018 built JLUR with 65K miles on it. It's used for exploring, not rock crawling. A good portion of those miles are off-road here in Arizona. My cracks are a carbon copy of Litebrite's cracks. My 4x4 shop snuck me in the day before Thanksgiving to keep me on the road ... thanks Letzroll. Ground out all old weld material and replaced with good welds. The old welds looked a little cold and stopped right at the end of both brackets. It's no wonder they cracked.
Passenger Side:
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... Passenger frame rail
Driver side:
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... Driver frame rail
Side:
BDinTX
Dallas, Tx
I know this is an old thread but it’s spot on what I found on mine yesterday. Mine is a 2021 with 32k miles on it.
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... IMG_1297
Passenger side where it ties into the frame:
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... 71009911903__BD362FCC-B3FB-410A-A571-61A9EFE87509
And where it ties into the crossmember:
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... 71010400401__DF4D6672-B90B-46B2-9EE0-2990F5DD1F36
Jeep Wrangler JL 2018 JL upper rear spring perch failure..... 71009917132__444A2EF1-B8E5-43DB-B680-55701CCDBEB6
Since it’s a diesel the exhaust runs down the passenger side.
