2018 JL needs a new engine
BrianCM
New Jersey
2018 Wrangler JL Unlimited
Hi all! I'm new to the forum, hoping to get help from @JeepCares . I own a 2018 JL Wrangler, purchased in 2019, currently has 52000 miles and the engine (2.0 Turbo) needs to be replaced. Of course it is out of warranty and I just paid it off recently. I've owned a Grand Cherokee & a Durango in the past and had just bought a pre-owned 21 Durango so I've liked Jeep/Dodge for quite some time but this has quickly changed my opinion of the Jeep product. Engines should not fail this quickly. Also parts are backordered so I'm not sure when I may even see my Wrangler again. So frustrating...
Brad Hearing
Alberta Canada
2024 Sahara V6 auto
horrible luck mate, but if its out of warranty what do you expect the manufacturer to do exactly?
totally agree engines should last longer but the more complex something is the more likely it will break down and turbos are complex. there needs to be more options without them.
munkeymike
Tx
So what's wrong with the engine?
mwilk012
2018 Ocean Blue JLU Rubicon
Service
What is wrong with it? You burn it up? Throw a rod?
Riverjeep
Va
25 Rubicon Unlimited, F-150
What help are you looking for Brian, you are giving very little information?
BrianCM
New Jersey
Mechanic found an oil leak, took it to the dealer, they found oil leaking from either the head or timing cover. 2 cylinders with scoring on the walls after compression test and bore scope.
I was hoping that the manufacturer would back their product and help me out but from what I've read, I'm stuck with a bill I can't afford and a vehicle that I can't drive for the foreseeable future.
Sh$t happens...
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Out of warranty is out of warranty.
Try finding a used engine at a wrecker.
MarkM
Fort Collins, CO
2019 JL Sahara 3.6
Project Manager
Hate to say it, but you might be hunting a new engine.
I know a lot of shops can rebuild or source parts for the Pentastar, but I don't know what all is available with the 2.0.
Jeep Cares tends to be anything but caring with major issues, more so out of warranty. If you have good service records and no abuse, they might meet you somewhere in between. I have done that before with manufacturers when a failure seemed to be totally ridiculous. It can't hurt to try, but don't get too excited.
Can you give details as to what happened? Needing a "new engine" is a bit nebulous, does it have a bad cam or an extra inspection port somewhere? If you can get by with a new head, that is almost a win in some ways.
GAJeep2025
Amy
Atlanta
2020 Jeep Wrangler
We have a 2020 Jeep Wrangler Unlimited Sahara 4WD (4 Cylinders N 2.0L DI Turbo DOHC 122 CID) which also needs a new engine. Our Jeep was leaking coolant and the service department had to take it completely apart to determine the cause. I don’t really understand the cause, however. The engine is on backorder until mid-July!!! Luckily we have an extended warranty but it only provides a rental for 5 days. Our Jeep has been at the dealership since 4/24. We have had no luck with Jeep Cares.
hamiamham69
Nantucket MA
2019 Unlimited Sport
If you search the inter web there may be known problems with that engine in which a design defect is causing premature failure. If so you might have a case for goodwill.
You would still be stuck with the same bill for labor but a reman engine from a legit seller would be more cost effective and are generally available.
I’m not as familiar with that engine vs my 3.6L but I would agree that 50K-odd miles is way too soon for an engine failure
kah.mun.rah
Merenkahre Jr.
Duat
We have a well maintained Jeep Wrangler that currently has over 240K miles on the engine. Expecting Jeep to pay for a 7 year old engine that was not maintained and lasted less than "normal" is like Jeep asking me to pay them more money since my engine has lasted longer than normal.
mwilk012
Service
If your so called mechanic can't fix an oil leak, is this who has been maintaining it for you?
What is actually wrong with your engine? An oil leak? Just fix it.
Opus
Midwest US
www.jlwranglerforums.com
I'm sorry to hear this, OP, and not just because I also have a 2.0. And I agree that an engine shouldn't fail that quickly so I'd be curious to know why this one did. But I think asking Jeep to "back their product" is a moot point. They did back their product... for the entire length of the warranty.
