2.0T Only has ONE battery?
4doorturbo
Tyler
Orlando, FL
2021 JLU Sport S
So, when I disconnect the ground on the primary battery will it also disconnect the aux battery as well? Assume they are wired in parallel?
JaysJL
Jacob
Phoenix
2021 JLU Altitude
It’s located right below the normal battery a real pita to get out if it’s dead
Ormond Beach, Florida
Retired at 55 ..
@JaysJL
Actually, the 12Ah 200CCA AGM, Aux battery, if your JL ha one is located directly under the Power Distribution Center and not under the Main battery.
It's not that bad to access via front fender flare pull.. but sure not as easy to get to as the Main battery.
Retired at 55 ..
For those that would like to know what exactly you have equipment wise to include batteries, you can click on this link and then insert your JL's, VIN # at the end of the link and press Enter on your keyboard again..... You will then be given your JL's equipment list in PDF form which you can save and or print out.
https://www.jeep.com/webselfservice/BuildSheetServlet?vin=
SirMagnus89
Charles
Massachusetts
2018 Jl Sport 2 Door, Mojito!
Simple solution. look under your own hood and do alittle digging for the second battery......
Retired at 55 ..
@SirMagnus89
Funny..... it is not that easy.... You cannot see the Aux battery when you look into the engine compartment. You'd have to do a lot more then "a little digging" to see/find the Aux battery...
OMTBiker
Derek
Ohio
2021 JLU 80th Snazzberry
Information Technology
Genesis guy may be smart, but he is still wrong.
2.0T ESS has small battery under main.
The *only* production jeep JL without aux battery is the 3.0L, without ess.
The 3.0L has ESS and a second battery as well.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
When the 2.0 T first came out, they were only Etorque with no second battery, so it depends one when the battery question was asked. Originally the 3.6 was the only engine with ESS, that's why the majority of ESS discussion is in the 3.6 forum.
MattT69
Matthew
Jeep Wrangler JL Rubicon
Hahah I’m sorry I’m just trying to provide factual information for everyone’s benefit!:like:
Many people will assume they only have one battery because the non-etorque auxiliary battery is underneath the power distribution box in an extremely terrible location and it isn’t visible at all when looking in the engine compartment. But I assure you, if you have ESS, you have the second auxiliary battery.
So when they install the Genesis dual battery system , they remove the aux battery and it gets replaced with the top mounted aux battery. Which is a better location.
Also what is the purpose of these extra batteries (aux and 48v e torque)?(I have e torque that why I ask) And which one is required to start the main one or is the main one used to start the engine without the help from the others?
MattT69
Matthew
So how does ESS system get its power? From the 48v e torque battery?
Also what is the purpose of adding the small aux battery in latter models???
OMTBiker
Derek
Ohio
The ESS uses the 48v battery when the engine has eTorque, the 2.0 eTorque was dropped and replaced with just ESS.
To break this down, all Wranglers have 2 batteries.
Regular ESS models have the main 12v and small 12v auxiliary battery
eTorque models have the main 12v and 48v secondary battery.
HTH
four low
central New York
2018 JL
Even for the 2021 ? Maybe they went back to the one battery, like the older ESS Cherokee,would explain Genesis reply
