2” Lift, now multiple error codes
Boz
Eagle, Idaho
2019 Wrangler Sahara JLU
Recently did a 2” lift myself with an experienced mechanic buddy. Lift went great and been driving a few times (100 miles) with no issues. Driving on 33’s. Went out today and I got multiple error codes. ABS failure, ESC warnings, service 4wd, and check engine light.
After doing a bit of research, it seems the speed sensor cable was potentially damaged during the lift. Either stretched, or otherwise. After closer inspection, it looks like my front right speed sensor cable has a slight slice through the outside rubber and I can see the wires inside.
Could this be the culprit? It’s just odd because I have driven for a week with no problems. Anyone have experience with this? Any help is appreciated. Thanks.
Jeep Wrangler JL 2” Lift, now multiple error codes A8941876-E16D-44B4-856D-C30DF7B51801
Jeep Wrangler JL 2” Lift, now multiple error codes 831E0783-19D0-4F8B-B4AF-151D42B703FD
Reinen
2021 Jeep Wrangler JL Rubicon
Definite possibility. You'll get all those codes if a speed sensor goes out.
I think you sliced the insulation but not the wires, then water got in there and started corroding the wire which messed up your speed sensor reading.
Boz
Boz
Eagle, Idaho
Thanks. I figured as much. Anyone ever do an install on one of these? There are plenty of videos on doing one on a JK. Is the process pretty much the same?
Boz
Boz
Eagle, Idaho
Here are some pics of the sensor wire. Part number to replace is 68394210AD.
Jeep Wrangler JL 2” Lift, now multiple error codes D9AF93DD-9F10-496D-AE00-72DA10126649
Jeep Wrangler JL 2” Lift, now multiple error codes CB718652-B298-4B2D-AC2E-070FCAFAA74B
Reinen
Not exactly. I had a wheel speed sensor go out and then it functioned again, so the error codes you're seeing looks very familiar. The L/R wheel speed sensors were swapped to pinpoint where the problem was. It never happened again. I'm guessing it was just a loose connector that happened to be reseated when the sensors were swapped.
Boz
Boz
Eagle, Idaho
Just as an update…​
I ended up cutting the wire where the split was. Stripped it and re-connected it with some solder heat shrink water proof connectors. Added an additional heat shrink wrap. All the error codes immediately went away. I am happy I identified the problem. Thanks to those that wrote in this thread. It’s a temporary fix, as I would prefer a new cable.​
zrickety
Technician
Just as an update…​
Nice work. You or someone else had posted a similar problem a week or so ago...looks like it got pinched?
Boz
Boz
Eagle, Idaho
Most likely got pinched or sliced during the install. Apparently, it happens a ton during off roading too. It looks like one of my wires was split. Glad it wasn’t anything more than that.
