18 Jl windshield (frame) repainting advice
h77_mar
Canada
2018 JL
My 18 JL has the typical corrosion (galvanic? I think it's called) for the most part its just bubling but one spot has flaked off. Im looking to get something done about it, but I'm concerned if I take it to a shop to just get the windshield repainted that it will happen again. Is there any special process involved with this typoe of repainting? Or am I good to go with a regular paint shop type of job? I have put some thought into having some part of the jeep painted with bed liner for Wear resistance. Would that be something that may hide/hold up longer term than normal paint?
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Windshield frame? To do that properly, the windshield glass needs to be removed. It can’t be reused, so you will get a new windshield out of the deal.
The easiest, and likely cheapest way would be to get a new windshield frame, have it painted, with new glass, then just swap it for the old one.
h77_mar
Canada
2018 JL
Why not just repaint the one on it? Either way Id be replacing the glass, so why get a second one?
The Last Cowboy
San Antonio, TX
No need to completely strip the paint down to bare metal, and repair the corroded portion. Saves money on labor, which is the most expensive part of the repair. Ask the shop when you get an estimate.
JPAloha
Saskatoon
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE, 2018 JL Rubicon 2 door
Accredited Financial Planner
The windshield ca, if removed carefully, be re-used (I’ve done exactly that).
The frame is likely repairable/repaintable, a good paint shop will be able to advise on what is needed to reduce the chances of it corroding again.
Maybe he's British?
I am British, we still don’t paint windscreens 🤣.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I didn't realize it was called a windscreen there. Here "screens" are porous to let stuff smaller stuff through. Like a window screen, which lets air through, but not bugs.
h77_mar
Canada
2018 JL
would it be best to repaint it with paint or something thicker/more durable like a bedliner? Ive already thought over doing that for branches hitting the frame but Im thinking maybe a thicker coating like bedliner might not bubble or at least not be as noticable if it does?
My26ReconWillys
Ed
2026 Jeep Wrangler Willys
I am not a professional painter but have painted my Chevy Nova 3 times in the last 24 years. I have also painted parts on my Harley.
When I got the Nova, it had the same rust you described. I repaired the cancer by sanding down to metal and using fiberglass reinforced body filler. It has never bubbled up.
You have options all dependant on skill, time available and money. Here are two.
1) Easiest but most expensive: Take it to a reputable shop and have them do the repair or replace/paint the frame.
2) Cheapest, most time and skill involved: Do it yourself. Have glass removed or remove glass, sand down to metal, treat metal with rust inhibitor, use body filler, primer, sealer, paint and clear coat. Will take skill and time. Dry times, sanding, paint curing depending on hardener used, etc.
The quarter panel on pic 1 had rust, picture 2 is after paint, before wet sanding and polishing.
I hope this helps
Best
Bedliner looks good for a couple years, then starts to get a coal-like look and looks pretty bad, IMO. I'm not a fan of the stuff.
If this is an aluminum part, the process used on airplanes is to mechanically remove the corrosion, acid etch, then Alodine, then zinc chromate prime the surface, then paint. Jeep basically skipped the etch, alodine and sacrificial primer steps. They didn't seem to know squat about protecting aluminum.
Terrymo
Terry
2023 JLURXR 3.6 ET
Windscreens, boots, parcel shelf, bonnet, chubby box…you can understand the confusion.
JPAloha
Saskatoon
We do still say hood but it’s the roof of a convertible - how you guys moved it to the bonnet is beyond me.
Unsure what a chubby box is but it’s you guys that messed around with our language 🤭🤷🏼‍♂️🇬🇧
