gt5426c
GA
JLRU
I installed a 392 takeoff suspension this past weekend and was pleasantly surprised with how the Rubicon turned out when I finished. It cost less than $500 and I came away with 2.1" of total lift (within 1/10 on front and back) and drives as I would expect. This is with the Mopar front and rear steel bumper with winch.
I thought it might be helpful to pull together all the information I used for anyone looking to do the same. So here are the details below. If anyone has any additions or corrections please feel free to jump in.
First, I heavily utilized the post from @Herson for this project. Thank you so much for the information and work you put into that.
Before geting started with I familiarized myself with two youtube videos and the 2" lift installation guide:
Having two floor jacks for rasing and lowering specific side of suspension was very helpful. This was my first time having all four corners on jack stands. I used 6 ton jacks stands and referenced this video:
The only parts needing to be installed are the springs, shocks, and swaybar links. Before beginning the install I took painters tape and labeled every part by location. Shocks only need to be labled front or back, springs need to be labeled by corner. This was tremendously helpful.
I walked through Mopar's 2" lift kit install guide, step by step. IMPORTANT: Be sure to loosen all parts as detailed and obviously don't remove any parts you aren't replacing. Keep all nuts and bolts for reuse.
Finally, here are a few notes that I found to be important:
  • Remember that on the initial install, bolts should be snug, but not tightened. You don't torque everything down until after the Jeep has been lowered.
  • Be sure to remove all electronics before dropping suspension for spring and shock removal. This includes the front axle disconnect which I don't believe is mentioned on the directions. There is a red tab on many of these that has to be popped out. This is a bit challenging and I found a trim removal tool helpful.
  • One of the the fixed bolt on the sway bar links was spinning when I turned the bolt (both on set I removed and set I installed). I very carefully used a channel lock wrench to hold part on inside to keep it from spinning to remove and when tightening bolts.
  • Getting the needed leverage for some of these bolts can be very challening. Having a long handled wrench or extension (pipe) you can use with your wrench can be helpful.
  • For rear suspension I did not remove parking break, I did ensure it was not engaged.
  • Pay attention to how springs fit in to top collar, there is a ridge on the inside there that keeps it from rotating.
  • It's not overwhelmingly clear which end is up on rear springs. Smaller opening goes up.
  • One last note for the springs, if you are having issues installing, try adjusting lift under opposite axle to see if it raises or drops the axle you are working on. If suspension still isn't getting into place, make sure you've sufficiently loosened all associated components. Also, it may help to have someone push on the hub.
  • Rear driver spring was very challenging for me to install, I ultimately had to install it with spring rotated opposite from it's final position and then slowly work it into place. It was a pain to get the nub into the hole, but ultimately I was able to get it there.
  • I did not remove the inner fender liner.
  • After the install, you will likely need to adjust the draglink to get the steering wheel straight. Will most likely rotate front to back to rotate the wheel clockwise.
A before, during, and after pic for your enjoyment.
Before:
Jeep Wrangler JL Tips for 392 Suspension Install on Standard JLU Rubicon IMG_2887
During:
Jeep Wrangler JL Tips for 392 Suspension Install on Standard JLU Rubicon IMG_2918
After:
Jeep Wrangler JL Tips for 392 Suspension Install on Standard JLU Rubicon IMG_2926
IceBerg
SW Missouri
2021 XR 392
Nice little write up. How does the ride feel?
I have a XR 392 take off suspension with 10k miles on it and I couldnt even sell it on FB for $100. IF you say it rides ok I'm going to gift it to a local jeeper with a JL that is talking about doing a small lift.
Also did you rerun your parking brake cables or was there enough slack in them even at full droop to leave them in teh factory location?
gt5426c
gt5426c
GA
JLRU
The ride feels good. I definitely notice sitting up a little taller which I did not expect. However, I really haven’t noticed any change in how it drives. I don’t have any additional roll, still holds a straight line pretty well, etc.
Also, surprised you’re having issues selling. It seems like $350 - $500 is what they are selling forthese days.
Jtphoto
Thunder Bay ON
2022 Rubicon Xtreme Recon Granite Crystal
Not all Jeeps will react as nice as yours when you get 2” lift without all the supporting parts.
Was the 392 you got the suspension from a 392 XR? The XR has a 1.5” lift which has longer track bars and swaybar links as well as the taller lift springs.
Glad it worked out for you.
gt5426c
gt5426c
GA
JLRU
The components I purchased are from a non-XR 392. The suspension components from the 392 and JLU Rubicon are the same part numbers with the exception of the springs, shocks, and sway bar links. So, unless something went awry, any JLUR should not have issues. Sahara and Sports would need to change additional components.
Jtphoto
Thunder Bay ON
What I am suggesting is that you got 2” lift from the heavier springs which throws things off. A lift is a lift no matter how it is achieved or what springs are used. It does require other parts (the reason a 2” Mopar lift is expensive). The 1.5” XR factory lift has longer trackbars, longer shocks and swaybar links.
This is just an FYI. If yours drives fine then perfect. But if it starts to feel weird as you break it in those are a couple things to check.
blnewt
Brad
New Mexico
Just ask @cosine he knows!
gt5426c
gt5426c
GA
JLRU
Nice job!
Be sure to add longer LCAs if you haven't done so, will make the drive much better at speed :)
Here's my install w/ part# if you haven't seen it. If you don't plan to lift any further the Mopar lift LCAs will work well.
https://www.jlwranglerforums.com/forum/threads/rubicon-suspension-on-2-door-sport.40700/#post-919317
Thank you for sharing. So far, the drive is a bit more stable which I attribute to the track bar being very loose before. However, at that price point it's hard not to upgrade even if it's a very modest gain. Thanks for sharing.
Deki
Dejan
Glendale, AZ
2022 Ram 2500 PW, 2021 Chrysler Pacifica Hybrid
If you still have it, my buddy will buy it from you.
Deki
Dejan
Glendale, AZ
Get the Mopar LCA to get your caster back. It will drive much better on the freeway after those are in. The bolts on those are torqued to 190 ft lbs with the vehicle on the ground. I just did this install on my 24 Rubi and the only thing that’s different than the 23 is the front end link bolts can’t be reused on the pre 23 longer end links. Otherwise it works perfect. Also, make sure you torque to spec and then recheck after a bit of miles on the set up.
Jeep Wrangler JL Tips for 392 Suspension Install on Standard JLU Rubicon IMG_4357
gt5426c
gt5426c
GA
JLRU
My parking brake was already a bit loose, so your mileage may vary. But in my situation, the brake line still had some give even when fully dropped.
Herson
Herson
Michigan
2020 JL Wrangler unlimited rubicon
I did this swap a wile ago and every one said the same thing. The ride was even better that with the original springs and shocks. Nothing felt weird and I used the suspension for about 30k miles.
brentfield
Brent
GA
2024 JEEP WRANGLER Rubicon 392
if anyone is interested I got a complete set up off a 24' 392 for sale. Complete free float axles and all. EVERYTHING.
Front and rear AXLES. These are both Dana 44s but rear is the new free floating. These will come with Rotors / Calipers / brakes.
3. GEAR BOX Stock and electric steering pump.
4. Stocks Coil Springs off 2024 - stock comes with 2" lift. Not sure how what size to put for Coil - 2" lift I guess.
5. SHOCKS with only 600 or so miles on them.
6. REAR tire carrier / and Extra support bracket that JEEP came out with for helping rear door.
brentfield
Brent
GA
I am on the south side of Atlanta, GA if you are local and interested. not trying to get rich just tying to move this stuff and help pay for my big build.
edsantana73
Eduardo
Houston, TX
Jeep Wrangler JL Rubicon
Do you still have the suspension avail.? I might be interested in buying
