Yes, another aux battery question..
K9WG
Richard
Greenfield, Indiana
2021 Wrangler 2-door JL Firecracker Red
Retired - Well kind of.... Electronics associate for a defense contractor. 2nd career :)
To the best of my knowledge my '21 JL is stock from the factory, aux battery included. When I am running the radio etc. in acc mode it this pulling off the aux battery?
Thanks
Rich - K9WG
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Thanks
Rich - K9WG
Yes.
A dual AGM battery JL that is factory configured always taps the Aux battery.
The only question is if the main battery is also tapped, which tends to not be the case in engine start stop events until the end, in which the main battery seems to effect the engine crank.
In all other cases, whether parked or in accessory mode both batteries provide power, including to your radio.
THAW
Foster
23 JL4DrRubicon
The amount of time the AUX (ESS) battery powers Jeep electronics on its own is measured in milliseconds, and it never happens without the ignition in the RUN position.
So, both batteries power the radio while the ignition is in the ACC position.
andy29847
Andy
Trenton, SC
2020 JLUR
There are 2 starting regimes on the JL Jeeps with 2 batteries. A cold start is when you have to press the start button. An ESS start is when your engine starts (after a stop) when you release the brake.
In the case of the cold start, the 2 batteries function as 1. The 2 batteries are separated for ~40 milliseconds before the start so that the aux battery can be tested to determine suitability for an ESS stop. The batteries are rejoined before the start.
In the case of an ESS Stop/start, the 2 batteries remain together while stopped. When the brake is released, the batteries are separated. The main battery starts the vehicle. The aux battery keeps the electronic systems in the vehicle powered up. The batteries remain separated until the vehicle starts and then they are rejoined.
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Thanks
Rich - K9WG
In your perfectly harmless question Richard lies some irony (I'll explain.)
By good authority the Aux battery was an afterthought in dual AGM battery JLs that arose from issues testing the vehicle prior to its 2018 release, where drops in voltage as the main (at the time of this testing the "only") battery would crank the engine at the end of an engine start stop (ESS) event, and the somewhat sensitive electronics of the entertainment system, would result in that entertainment system giving off a crackling sound. Some owners running ESS events having bypassed the Aux battery report this.
Of course you asked about accessory mode when the engine is off. And since at all times but an instant and cold crank to test the Aux battery, and at parts of an engine start stop event, the batteries are connected together in parallel, so indeed your Aux battery plays role in powering the radio, if not an exclusive one.
