AndySpill
- Andy
- Oct 24, 2023
- Pittsburgh
- 2018 JL Sahara
Y.A. stands for yet another.
And I'm sorry for that but the issue I'm about to report isn't one I've read about or can find with searching: which isn't to say it isn't in some post.
And sure, turning ESS off, disconnecting the Aux battery, yanking Fuse 42 and/or jumpering N1 and N2 in the PDC: probably what I should do but I live in a fool's paradise that assuages my guilt for driving this "gas guzzling anything but aerodynamic box on wheels" by doing my part to save gasoline at red traffic lights. I trickle charge with solar so at least the savings in gasoline isn't offset by that in the electric to run the trickle charger.
It's illogical, I know. I'm in Jeep therapy.
So I'm on a parkway that has lights. I've been doing a fair speed for a fair time with my trickle charged batteries and get to a known long red light. No climate control fan's running that might early terminate the ESS event I'm about to enter.
At some point during this long light the ESS event ends early, I guess the ESS battery voltage got too low, the two batteries are brought back into parallel and the engine cranks, but the EVIC turns ESS off, like there's a problem with it.
This typically goes away at the next cold crank. It only happens rarely.
Has anyone had this? Low ESS battery voltage during an ESS event is suppose to simply force an early engine crank without complaint, not generate a problem.
Thanks in advance.
Thanks in advance.
