Wires through the firewall
Captain Skip
Skip
New Hampshire
2020 Wrangler JL Sport S
Happily retired
I’ve seen a number of posts about the plastic plug on the drivers side being a good spot to run wires through the firewall. If you have an automatic it’s perfect, if you have a manual that’s where your clutch lever comes through the firewall. I needed to run some wires for my tow harness to the brake pedal as I will be towing my JL behind my motor home. People have recommended pulling the plug out with pliers. Not necessary - I looked under the dash, found the plug and pushed on it with 2 fingers, popped right out. I didn’t like the idea of drilling a hole than slathering on silicone to waterproof it so I took a different approach. I picked up a package of diaphragm grommets at O’Reilly’s Auto. The center is 1/2” and requires a 5/8” hole to mount it. Wires poked through the center with no problem and the rubber stayed tight around the wires. No need for silicone and if I have to remove the wires or add more it’s no problem. Figured I would pass this along/
Jeep Wrangler JL Wires through the firewall 573077D9-BDCC-456E-BF06-7669261C74E0
Jeep Wrangler JL Wires through the firewall DC9A1FAA-5AAC-4637-B7B5-F8D0FE3CA103
Jeep Wrangler JL Wires through the firewall 47B47A50-1DD2-4A37-93E9-AB91294D75F4
MEHillwalker80
Tom
Maine
2019 Wrangler Sport S JL 2 DR 1999 Chevy Suburban K1500
Good find...Thank you. I'll be buying those.
Brew211
Peoria, Arizona
2018 JLURM, 2022 392 XR, 2024 F250
Great job! I have a manual too, can you show me a picture of where this is in the cab and engine bay?
Thank you
Ormond Beach, Florida
Retired at 55 ..
Thank you
@Brew211
You JL is a manual shift so you will not find this point of entry / this grommet that is found on an automatic tranny JL.
There are other ways to get to the cab. Do a forum search for same.
Punknhed
Virginia
2023 Punkin Rubi XR
Copy, thank you!
on the right side of the fire wall there is a gromet with a "nipple" on it, that is where i ran my wires for my compressor thru the fire wall. it is a pain in the ass but it worked. (my Jeep is a stick too)
Bpg2310
Los Angeles, CA
2020 Jeep Wrangler Unlimited Rubicon
This may be a silly question, but you had to drill a 5/8” hole in the plastic cover correct? Then insert the grommet?
