Window Tint
Laz
Tom
New Hampshire
2018 JLUS
Want to tint my front windows but probably not as dark as the back. I don’t want to lose much vision at night.
Any recommendations? TIA
yokramer
A Land of Petty Tyrants
Snark Incarnate
35% with a good UV blocking ceramic film is the way to go if you dont want it to be too dark but still work and is within legal limits pretty much everywhere. I also recommend a 55% on the windshield in the same stuff does wonders.
azwjowner
Phoenix
30 to 35 percent for the front. I believe 30 is the legal limit in my state, and that's what I do. Most states are pretty good at setting the legal limit at a reasonable level, so just tell your tint shop you want the legal minimum.
My prior Jeep had darker tint in the front and it was dangerous at night -- hard to see; I'd have to roll the windows down sometimes before making turns. Also impairs eye contact with other drivers and pedestrians.
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
I roll with 20% on the fronts to match the sides and rear and 50% on the windshield. Helps in the desert summer for sure.
although it may sound dark, I like it and I haven’t had any issues. Legal or with seeing out. I think 35% is the limit in my state
4x4 Mule
Ohio
‘26 Wrangler Willys T-4 - ‘26 Durango GT 5.7
boer goat wrangler
I just did a 20% tint/high UV protection on the front side windows to match factory rear side and back tint. It looks good and I like it a lot. I had a 30% tint/high UV protection put on the windshield and I’m probably going to have it removed this fall. I like the UV/heat protection on the windshield but to me it seems slightly blurry to look thru. They had a clear high UV protection I wish I would have put on the windshield and may try that after the tint is removed. It has cut interior heat down substantially.
BAKNBLK
Nevada
JT diesel
Expel makes window tint, have it on all my Vehicles. Talk to your local installer.
