Winch power/ground wire routing?
Rufus
NYC
2018 2 door JL Sport 3.6 V6
Search here came up empty.
When wiring my winch, is there a preferred route from the winch up to the battery for power and ground cables?
Looking up from under the Jeep there was no obvious path, so do I just fish around with the help of a friend and try to find a good clean route?
I’ve seen a video on YouTube with a routing, I’m just wondering if there’s consensus on the best route.
Thanks.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Thanks.
Routed mine up behind the grill next to the passenger headlight and then along the fender to the battery. I have a rugged ridge spartan bumper so it is pretty open without the stock components.
Kevin Mojito
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
Rip the passenger side fender off. It will make things much easier.
Chocolate Thunder
Jeremy
OEM steel bumper with Smittybiky X2O. I simply routed them from the control box, under grille, behind passenger headlight, under air intake, up to battery terminals. It was fairly easy.
KansasJL
Kansas
2019 Sting Grey JLUR
I have a LOD Destroyer shorty bumper and I couldn’t find any way to run the wires and have them as protected as I wanted. I popped off the grill and started messing around. I found a tube that runs from the front of the grill to under the air box. I cut two small holes in the honeycomb on the grill inserts and ran the wires thru the grill and that tube. You will have to take the air box out which is pretty simple.
Jeep Wrangler JL Winch power/ground wire routing? BDBEB70D-AA93-4DF2-A35C-3974A767EA26
Jeep Wrangler JL Winch power/ground wire routing? FE25E37C-C406-4889-8B9A-9ACCE0BFE179
Rufus
NYC
Thanks, nice job!
I wound up just going under the grill and up the passenger side of the engine compartment by the wheel well and followed along to the battery. The wires aren't the cleanest looking going under the grill but they're largely obscured by the winch itself.
KansasJL
Kansas
Thanks, nice job!
I couldn’t squeeze the wires under the grill and the back edge of the LOD bumper and I didn’t want to route it anywhere along the frame and risk it getting hung up or pinched. i did have it routed along the edge of the radiator but the wires were starting to get warm and I didn’t want to risk rubbing off the coating or it melting causing a HUGE problem.
Rufus
NYC
Yeah I have a sufficient gap with the ADD bumper.
