Will a 35x12.50R17 require a spare tire relocation bracket?
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
Upgrading my tires/wheels on a 2024 Sahara - will the spare fit with the stock bumper or do I need a relocation bracket?
Rob
Cincinnati
JK, JKU, JL, JLU, 392, JT
tomk62
tomk62
Tom
South Carolina
Thank you.
So the implication is that tires with a specification of 35" x 12.5" x 17" wheel diameter are actually all slightly different dimensions. :)
aldo98229
Aldo
Bellingham, WA
Market Research
You will need a relocation bracket, otherwise the bottom of the tire will bump into the rear bumper.
I went with the Smittybilt spare tire relocation bracket: it pushes the spare tire one inch away from the tailgate and two inches up from the bumper. It is simple and inexpensive.
Jeep Wrangler JL Will a 35x12.50R17 require a spare tire relocation bracket? 1692719815972
WantToWander
Austin
2023 Rubicon 392
I upgraded from 285/28/17 to 315/70/15s on a non-XR Rubicon 392 and found the spare tire rubs on the rear bumper using only the Mopar Reinforcement Kit (82215356AC).
I plan to add the Mopar Oversize Spare Tire Carrier Mounting Bracket Kit (82215355AC) to address this.
A short term fix has been to remove the rubber pad on the top center of the rear bumper. That allowed the tire to fit, but it looks bad.
Another issue was the Rubber Stoppers that are supposed to contact the read tire to provide more stability do not reach the tire. The Oversize Tire kit looks to include longer Rubber stopped that I hope fit (contact / support the tire).
Thanks,
john
mawz
Adam
Toronto, Ontario
'24 Sahara
IT Manager
Thank you.
They do vary between tires. K02’s for example are notorious for being undersize in diameter
2nd 392
Ca
Some 35s fit others don't. We typically will recommend/install the TeraFlex relocation bracket. It allows for the entire carrier to be spaced out and up to clear the bumper while maintaining all OEM wiring and functions of rearview camera.
https://highliftoffroad.com/products/jl-spare-tire-relocation-bracket-kit
These brackets are great as long as you keep the tire/wheel weight down. Featherweight, easy install, only ~$150. I didn’t even unplug the wires as per directions. Just set the carrier on a residential dumpster. I got 59 lb Toyo AT3 35-12.50-C on stock 392 wheels and the total weight including brackets is ~the same as factory 285-70 MT’s, reinforcement not required. ? PS— relocation was required.
botlfed98
Brandon
NWI & Tulsa
2019 Wrangler
that's kinda funny, i wouldn't think it would make that much of a difference
RockAltered
Flowery Branch, GA
22 JLR V6 AT & 23 Ram Limited 4x4
Retired.
On my rig 35psi doesn't clear the steel bumper without severe rubbing.
zouch
Berkeley, CA
XJ, JLUWD
will depend on which wheel, which tire, and which bumper.
all are variables.
best to plan on doing something to manage the spare.
if you have 100% certainty that you're never going to go to a larger tire, the Mopar stuff works fine. if you're thinking of ever going to a 37s, the Mopar stuff probably will not hold the tire to where it clears the factory bumper, and the tailgate will likely be tweaked by the extra weight.
moving directly to a proper frame-mounted tire carrier like the Teraflex or an aftermarket bumper with a tire carrier would be something you might consider to save the cost of upgrading through some other less optimal options on the way to what works.
racerdude90
JLUR
Like others said, best approach would be to plan on getting one. That said, if you have a plastic rear bumper it will probably fit. The metal rear bumper is ever so slightly taller in the middle part where the tire sits so a lot of those guys experience some rubbing.
You don’t wanna smooth out a flat spot on a tire before it even hits the ground haha
jessedacri
Jesse
Lake Arrowhead, CA
2019 Bright White 2dr JL Rubicon 3.6
I've had a 315 Milestar Patagonia MT on there for like two years and am over a year in now on 37x12.50x17 BFG KM3s with stock tailgate and have no sagging or any other issues whatsoever. Pretty good amount of wheeling and long routes like Mojave road have been done with this setup.
The 315 didn't rub the OEM steel bumper - the 37s did initially but after removing the small piece of plastic in the spot where the tire rests on the bumper and doing their first 5-tire rotation, it doesn't rub too much anymore. Slightly rests on the ledge of the bumper.
I'd be ready to look at options if your specific config is crazy heavy (nittos on deadlocks, for example) or happens to rub but I wouldn't say it's required in all setups.
bn13Cooper
CT
2018 Wrangler JL Unlimited ~Granite
I just took delivery of a 2024 Willy's with backup sensors. I put my 35 KO2s on (I know they're a little smaller than 35), and the sensors keep going off/then I get a message that they won't work. Any idea if I use a relocator if this will help?
tomk62
tomk62
Tom
South Carolina
It will not help. The sensors still activate with my relocation kit.
The trick seems to be to put some clear packing tape on the tread of the bottom of the spare. Solved the sensor issue for me and others.
