Which Adjustable Track Bar?
MntsRcalln
Virginia
2020 JLUR, 2011 Dodge Ram Bighorn, 1990 Totoya 4x4 Mod
I have seen many posts and brands. I kinda wanted to get more info on the whys and why nots on certain brands. I know everyone has their brands they like. I'm running a leveling kit and 35's. Planning on Teraflex Alpine IR LCAs.
I am leaning towards :
Steer smarts adjustable.
Teraflex alpine ir adjustable.
Thanks
Fonzilla85
Fonz
Ventura County, CA
2018 Jeep Wrangler JL Rubicon Unlimited
Lawman
I’m running a JKS track bar. It’s well made and gets the job done, no complaints.
SmilesPerGallon
2015 JKU Sport, 2021 JLU Sport
Chrisdupe
Massachusetts
2019 Jeep Wrangler JLU Sport
I run the TeraFlex. It's beefy and i have no complaints. BUT if i were to do it again i'd probably go full Steersmarts with their track bar, tie rod, and drag link.
Stormin’ Moorman
Georgia
19 JLUR, 20 JLUR, 21 JL, 21 GCL, 89 YJ, 04 LJ
Forester
I've had the Steer Smarts and the Rock Krawler. The Steer Smarts is the beefiest part on my entire Jeep. If my Jeep was struck by an ICBM, the only thing that would survive would be the track bar. I truly think its unbreakable. The RK is meh.
The only downside is fitment with after market steering dampeners such as the fancy Fox one with the resevoir.
MntsRcalln
MntsRcalln
Virginia
Doesn't look like I can go wrong with any of the ones discussed.
P&PJeep
Mesquite, NV
Jeep Wrangler Unlimited Sport
What front adjustable track bar are you running on a JL with a Fox Race Series 2.0 ATS steering stabilizer mounted on the tie rod ? I currently have a Teraflex HD and it is hitting the stabilizer at full passenger turn
Jeep Wrangler JL Which Adjustable Track Bar? Track Bar_LI
. Treaflex's solution is to install their JL / JT Front Track Bar Axle Bracket Kit (2.2-3.5" Lift). And they stated they cannot guarantee you won't have any issues with the Fox stabilizer as we do not test with other manufactures product. Any input would be greatly appreciated.
Roky
Roky
I can’t see the mounting bracket on the end with adjuster. Can you expand the pic to include it.
Roky
Roky
Hope these will work
Yeah, better. Looks like you have enough room on the trackbar bolt to put a couple of washers behind the the shock eyelet and will probably give you some clearance, it’s a cheaper solution, if it’s enough. Also you can adjust your turn stop out a little, that’ll will help too.
Jeep Wrangler JL Which Adjustable Track Bar? F4E05593-D6D0-4AA5-9E8B-01CB4DD99281
P&PJeep
Mesquite, NV
Thanks I will give this a go. Bump stops out by 3-washers both sides..
Roky
Roky
Copy that..... also if you need a little more room, you can swap that nyloc nut out with a regular nut, and use some orange loctite.
P&PJeep
Mesquite, NV
Sounds like a plan
Thanks for your help, really appreciate it.
