where is the front diff drain bolt?
Fuel Fire Desire
Michigan
2018 JLU Sport S, 2020 JT Sport
Nope. Another XR owner who recently took delivery is also seeing the same situation. I wonder if they are using a different part. Gonna be a PIA to change diff fluid.
At least it’s just the front. When I changed both of my diffs at 40,000 the front oil still looked brand new. And I use my 4wd fairly often. I could probably get away with doing the front every other time I do the rear.
rent
rent
Roaming Around
2021 JLUR XR
Oh yes, very true. Guess I won't need to worry about it for a while.
OllieChristopher
Southern CA
2005 GMC 2WD Sierra, 4.3, NV3500, 3:73/TruTrac
The cover should always be removed when changing diff fluid. It gives you a chance to clean and inspect components for wear and damage. It is not hard at all. 30 minutes tops to service provided components are within specs.
To make it easy on yourself always replace the cover gasket. It makes future service much simpler with less scraping. If you use silicone go real light so as not to get any into the cavity.
Jeep Wrangler JL where is the front diff drain bolt? 93F8DA93-2ECD-4688-B4EE-19F5CE5B2AE2
Jeep Wrangler JL where is the front diff drain bolt? 357377E0-3FF7-492D-B50C-E98D81FB356D
Jeep Wrangler JL where is the front diff drain bolt? 9F74CFB9-973C-46C6-8506-8C6DA6D8E660
Jeep Wrangler JL where is the front diff drain bolt? 5997C849-1CD7-4112-9ED8-B5DD8F260AFA
rent
rent
Roaming Around
2021 JLUR XR
Thanks for the pointers! I will try this when the time comes.
CarbonSteel
Change the rear early and a few times for the first 15K miles--I would dump it no later than the first 2K miles. These axles shed a lot of metal and have a reduced oil capacity versus previous generations.
Fuel Fire Desire
Michigan
Not to mention they use water thin oil. Mine was pretty black when I changed the rear (front looked new). No chips in the magnet luckily. Not really any glitter either.
CarbonSteel
Yep: either run 85W-140 or 75W-140. 75/80/85W-90 is a no-go for me with the reduced oil capacity and the temps at which these axles operate.
Deleted User 38384
Did anyone ever find a drain plug for the front diff??
I own a 2021 JLUWillysSportDiesel with the M210 front. No drain plug on the bottom of the front diff here either. I know there were a few other improvements/changes between the 2020 and the 2021 model years, ie. the backup camera is attached differently between these model years too.
Anyone find a drain plug, or do we have confirmation from a dealership that the drain plug's been removed??
word302
Oregon
JLU
Do you really need a dealership to confirm whether or not your diff has a drain plug?
Deleted User 38384
Found another thread which was more informative. But as this thread ended, yeah, no definitive answers were presented, the dealership is your local Jeep Representative. So yes, if I didn't find the other thread, I would've contacted the dealership to make sure I wasn't missing anything.
