angrynewyorker
Does anyone know when the block heater option is installed? Is it installed during manufacturing process, or is it added later in JB?
I've never visited the Toledo plant, but I would presume that the block heater is installed at the engine assembly plants, and the wires are tucked/packaged until the engine is loaded into the frame. Once the engine is in place, the wires are unpackaged and run to where they need to go.Does anyone know when the block heater option is installed? Is it installed during manufacturing process, or is it added later in JB?
Then they would have to have 2 different sets of engines to pick from, those with block heaters and those without. I guess it’s possible, but seems like that would be a hassle for them.I've never visited the Toledo plant, but I would presume that the block heater is installed at the engine assembly plants, and the wires are tucked/packaged until the engine is loaded into the frame. Once the engine is in place, the wires are unpackaged and run to where they need to go.
Have a look at this video.
JP18
Not really. Engines and other large assemblies are often built for a given VIN. For instance, the entire dash assembly comes in pre-assembled, regardless that it's a Rubicon or a Sahara, and whether it has the auxiliary switches or not.Then they would have to have 2 different sets of engines to pick from, those with block heaters and those without. I guess it’s possible, but seems like that would be a hassle for them.
Oh, ok. I was thinking the engines were built in Italy and shipped in, then they added block heater there somewhere. I think I heard there was an engine plant there in Toledo? Maybe they add it there according to the order?Not really. Engines and other large assemblies are often built for a given VIN. For instance, the entire dash assembly comes in pre-assembled, regardless that it's a Rubicon or a Sahara, and whether it has the auxiliary switches or not.
Options are not added at the assembly plant, they are done by VIN and each part is tracked until it's installed.
Also, the wire looms are now custom built for each vehicle. The days of "one wire loom fits all" are long gone as the number of options is very high. [I have a friend that works with BMW in Spartanburg SC, he confirmed that is how BMW does it]
JP18
It's possible that the base engine is built at the engine plant and customized for the VIN further down the line.Oh, ok. I was thinking the engines were built in Italy and shipped in, then they added block heater there somewhere. I think I heard there was an engine plant there in Toledo? Maybe they add it there according to the order?
I can't speak for that. What I do know is that when the large assemblies are put together, all of the wiring and other connections are plug-and-play.My whole reason for asking was I was just hoping it was not added later when they add other options (tailgate reinforcement, etc...). From the sound of it that is not the case.
I think different wire looms are used for the JL too. I remember reading about a forum member wanting to add the proximity door option to his JL. His JL did not have the wiring in the doors for it or something.Not really. Engines and other large assemblies are often built for a given VIN. For instance, the entire dash assembly comes in pre-assembled, regardless that it's a Rubicon or a Sahara, and whether it has the auxiliary switches or not.
JP18
Very common nowadays. I had a 2000 Honda Civic that didn't have cruise control... and neither did it have the wiring!I think different wire looms are used for the JL too. I remember reading about a forum member wanting to add the proximity door option to his JL. His JL did not have the wiring in the doors for it or something.
