Wheels like AEV Pintlers with 0 Offset
Greymatter
Evan
Oregon
2021 JLU Willys
Love the look of the Pintlers but since I’m running a 34” tire, I can’t do the 25mm offset. Wondering what other wheels look similar that have a 0 offset.
JeepJLU402
Nebraska
2019 Wrangler JLU Sport S - V6 8AT - 30/44
Why can’t you run a +25 offset? If your looking at 285/75 17 I thought those fit Sports with stock rims and that’s like a +44 offset.
Greymatter
Greymatter
Evan
Oregon
2021 JLU Willys
I think it would be too much tire outside the fender.
Cypher
J
AZ
Cybersecurity Leader
My Method MR702s were 0 offset. I loved them as far as looks etc. they tucked very well with 35" tires. (I ran them with and without a lift with no issues.)
Jeep Wrangler JL Wheels like AEV Pintlers with 0 Offset C3421C1E-5472-43E8-8FA7-0B3FB1ECC141
Jeep Wrangler JL Wheels like AEV Pintlers with 0 Offset 541F1333-8244-4F4A-A4E6-2E8F5F5B442B
Greymatter
Greymatter
Evan
Oregon
2021 JLU Willys
I have a set of 701s on order but prefer the Pitners or Saltas. I will be running a 34" tire and concerned about the tire sticking out with the offset
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
The JK AEV Pintlers have a +10 offset and the same wheel bolt pattern.
Size: 17" x 8.5"
Weight: 33 lbs
Bolt Pattern: 5x5
Offset: +10mm
Approximate Backspacing: 5.2"
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
I think you have offset figured out wrong.... the higher the offset, the more your tires will be inside the fenders. So the AEV Pintlers with +25 offset, will remain inside the fenders or just barely poke out a little. The same wheel with 0 offset would be outside the fenders by a good inch or 2.
superdude
IL
2020 Wrangler JLU Sport
I run AEV Pintlers with 0.75" wheel spacers. 285/75/17 Toyo AT3's - they stick out maybe 1.5"
Jeep Wrangler JL Wheels like AEV Pintlers with 0 Offset PXL_20210320_235353433.MP(2)
Jeep Wrangler JL Wheels like AEV Pintlers with 0 Offset PXL_20210711_200128386
Midding
Chicago
2021 4xe, 2019 JLUR, 2016 Sahara Unlimited
I run the Saltas with LT315/70R17 Mickey Thompson Baja Boss A/T and have no stick out. Best pic I have at the moment…
Jeep Wrangler JL Wheels like AEV Pintlers with 0 Offset 64461C7E-0847-478E-892D-4C3E94472EDF
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
No spacers and no rubbing on LCA? I have a +30 17x8 wheel that sits the same as the AEV 17x8.5 +25s, I have not been able to find skinny tall tires and hence contemplating going to 315/70/17 due to more generally available options.
