Wheel suggestions
Blckdog
Blckdog
Connecticut
2023 Willys JLU
Seems like a lot of weight for a smaller wheel 8” vs 8.5” too.
Think my mind is made up. OEM will find a nice home for someone. And the all black wheel against the white body I really like.
2nd 392
Ca
Well, my 7.5” pre XR BCD wheels *are 31 lbs. The 8” shouldn’t be that much heavier, certainly not 17 lbs. I would want confirmation on the 48 lbs before acceptance.
• replaced with 21 lb 8.5” -1mm beadgrip knurled.
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
As an option, I'm running Mickey Thompson BB ATs 255/85r17 on stock 2025 Willys wheels (17x8") and like it so far.
shagles
Skylar
2020 JLU Sahara
adult toy engineer
XR wheel, which is the same as a 392 except rash rings instead of beadlock rings, and 315/70/17 BFG K02. I already did the math earlier, but you're welcome to do it again.
Jeep Wrangler JL Wheel suggestions 1775076181876-hn
Blckdog
Blckdog
Connecticut
2023 Willys JLU
Skylar, that trim ring is different than the OEM one I found for sale which have 12 bolts. Might make a difference In the weight.
yokramer
Snark Incarnate
Didnt the beauty rings later get half the bolts just like the Bronco ones you see with just a few in them.
yokramer
Snark Incarnate
Yea if you get the actual bead lock rings rather than the beauty rings these would be bolt holes too
Jeep Wrangler JL Wheel suggestions 1775076851719-zd
shagles
Skylar
2020 JLU Sahara
adult toy engineer
Odd. The pic i posted is the stock XR wheel off @gek's rubi XR that he got a few months ago.
Blckdog
Blckdog
Connecticut
2023 Willys JLU
Gotcha. Could always go with the Method 709’s for the bead lock look I guess.
yokramer
Snark Incarnate
Go with the 703s they are fantastic ... also if you sign up for the onX elite membership (normally 100 can bet had for 80 with numerous affiliate codes) you get 25% off your Method order
2nd 392
Ca
@shagles , That difference for 1/2” defies reason, that said, I wouldn’t run 48 lb wheels. I didn’t want the 31 lb wheels and went lighter. But kept them in case beadlock ever wanted.
nowhere near that much
Blckdog
Blckdog
Connecticut
2023 Willys JLU
That’s good info I was not aware of. Thank you.
shagles
Skylar
2020 JLU Sahara
adult toy engineer
Oh i agree, its absurd. I'm sure they changed section thicknesses and stuff to get there too. There should be no reason for them to be that heavy. I've seen similar numbers from people elsewhere too, not just the one.
2nd 392
Ca
Are you keeping them ? Performance, braking, and mpg will suffer with that much extra rotational mass. Forged wheels weren’t cheap, but my 8 1/2” wheel 35/12.50 AT3 combo is 80 lbs. Two less than the stock 7 1/2” BCD 285/70 KO2’s combo. Added bonus, no gate reinforcement needed.
