What does start/stop ready mean in the drivers menu option?
Wbino
NJ
jludave
The Isle of Long
IT Manager
Please read your owner manual.
STOP/START SYSTEM — AUTOMATIC TRANSMISSION (IF EQUIPPED)
The Engine Stop/Start (ESS) function is developed to reduce fuel consumption. The system will stop the engine automatically during a vehicle stop if the required conditions are met. Releasing the brake pedal or pressing the accelerator pedal will automatically re-start the engine.
ESS vehicles have been upgraded with a heavy duty starter, enhanced battery, and other
upgraded engine parts, to handle the additional engine starts. Vehicles equipped with eTorque
contain a heavy duty motor generator and an additional hybrid electric battery to store energy
from vehicle deceleration for use on engine startup after a stop as well as providing launch
torque assist.
AUTOSTOP MODE
The Stop/Start feature is enabled after every driver ignition start. At that time, the system will
go into STOP/START READY and if all other conditions are met, can go into a STOP/START
AUTOSTOP ACTIVE “Autostop” mode.
To Activate The Autostop Mode, The Following Must Occur:
 The system must be in STOP/START READY state. A STOP/START READY message will be
displayed in the instrument cluster display within the Stop/Start section
 The vehicle must be completely stopped.
 The shifter must be in a forward gear and the brake pedal pressed.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
I would add to the list that jludave stated that the engine needs to be warm enough. I noticed several times in the winter (we had some extreme cold in Feb) the engine would not stop when the break was depressed.
Ed Pursell
-Ed-
Lehigh Valley Pa, Allentown
2021 JL Willys- 3.6 Pentastar,8 speed Auto, Selec-Trac transfer case
Supervisor- MRO Buyer Maintenance- Pet food Mfg.-Now Retired.
That is correct, as outside temps warm up, e-torque will start activating more. Cold weather, it takes a while, I only got a 12 mile ride to work each day, when it’s 20 degrees it normally don’t kick in till the last couple stops before my work place.
