Weird issue with Baja Designs LP9 Pro's
offcamber
Bob
Dallas, TX
2012 Wrangler Unlimited Rubicon, 2014 Grand Cherokee Limited Ecodiesel
  • Thread starter
  • Banned
  • #1
I've had a pair of Baja Designs LP9 Pro's for almost 2 years now on my JLUR. I have the low beam wired to Aux 1, the High Beam set to Aux 2 with it set to momentary for safety. If I need to use the high beam then I switch it to latched mode. This prevents me from accidently turning on both high and low beams at the same time. Aux 3 is set to the daytime running lights. A while back while having the LP9 Low beams on, it began to flicker onto the high beams occasionally. About a week ago it changed so that anytime I turn the low beams on, it turns on the full set of LED's ie the high beams. I checked the wiring, nothing was broken or shorting or any obvious issues. Tonight I noticed that the running lights are not coming on at all even though the switch is on and lighted and the wiring is fine. I disconnected the wire connecting the high beam to Aux 2 yet when I turn on Aux 1, which should be low beam yet the light is fully lit on high beam now. The behavior now is that Aux 1 turns on the full light instead of some of the LED's to give it a low beam. Aux 2 does the same thing as Aux 1, high beam. Aux 3 the switch LED comes on and off but the amber running lights on the LP9's do not light up. Any suggestions?
