Was bound to happen...
marsheezi
Tulsa
2022 Jeep Wrangler Sport S - Bright White
Not even at 700 miles yet, my 2.0L JLU has it's first CEL showing up. P0301 which is a misfire. Called dealer and have it scheduled to go in week and a half to be looked at. The light has come and gone a few times here lately. Hoping they are able to get to the bottom of it quickly...
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
At least it’s cylinder specific. Should be quick to fix, unless it’s a major engine defect.
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
Be glad you got 700 miles. I had my first light in under 100 and another at ~1000... and only ~15 more between that and 40k.
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
Mine comes on every two months or so and stays on on for three start cycles before clearing.
marsheezi
marsheezi
Tulsa
Ugh. Unacceptable. Hope they just flat out solve it. Not thrilled with the idea of gremlins.
kah.mun.rah
Merenkahre Jr.
Duat
A check engine light just means that you received an authentic Jeep and not one of those fake imitation Jeeps. Best of luck, I know how frustrating it is. Unfortunately break-in pains happen the 1st year but after that you will love it forever...or until the next generation comes out that you have to have. :)
marsheezi
marsheezi
Tulsa
SMH...
"we found the codes stored. tech cleared them out and we have been driving it to see if we can get it to return. over 50 miles and still no light. So we are releasing back to you"
Tethmes
Dylan
Michigan
2022 JLWS, 2023 KLR650
Management
SMH...
That would be an unacceptable response to me. You taking it back or gonna make a scene?
mwilk012
Oklahoma
Service
You can make a scene all you like. You’d be the jackass.
If an issue is not reproduceable in 50 miles, then there’s not much anyone can do.
Tethmes
Dylan
Michigan
Management
You telling me they don't have a fix in the book for the code that was on the dash? My personal mechanic has a fix for whatever code pops up, why wouldn't the dealer? "Clearing the code" isn't an acceptable answer is all I'm saying.
mwilk012
Oklahoma
Service
You don’t seem to understand even the basics of diagnostic procedure of engine repair.
Tethmes
Dylan
Michigan
Management
call it difference of opinion I suppose. I take it to my guy, I don't have the problem anymore. ?‍♂
mwilk012
Oklahoma
Service
You seem to think that code = diagnosis.
Not even close.
P0301 indicates a misfire on cylinder 1. This could be due to a fuel, spark, air, or compression issue. Any of these could be due to any one of multiple different potential failure points.
All you can do with an intermittent cylinder specific misfire is a compression test, check spark plug condition for evidence of fuel/oil/coolant contamination, test drive it in an attempt to repeat the failure, and then return the vehicle to the customer.
Tethmes
Dylan
Michigan
Management
Not even close.
That's a lot different than "tech cleared the code and we drove it 50 miles to see if it came back" though, which OP gives the impression that that is all that was done. If it is the case that they actually performed diagnostics, then it's a different story. My comments are under the assumption that OP's account of the situation is true. Which may or may not be the case. Either way, I think you and I are having a misunderstanding.
If they came back and said "here's everything we did and we can't get it to replicate", then that's a different story. OP just makes it sound like they're being lazy about it.
