Warn VR EVO 10S & Warn Plate Install Pics
limeade
Guy
Reno, NV
what cover did ya'll use?
Like a winch cover?
I don't use one as my Jeep is in the garage. Regardless, with the stock steel bumper, the winch sits between the frame rails and the synthetic line is completely covered by the winch and bumper. The only reason I would consider a cover is if my winch sat on top of the bumper where the synthetic line is exposed to sunlight frequently.
Sean
Maryland
2020 Rubicon, 1984 CJ-7, 1999 XJ
How did you guys manage to get the inner bumper nuts back on? I have the Warn Zeon-8s and there isn't enough room to get in there and put those bolts on.
Any help or ideas would be greatly appreciated.
limeade
Guy
Reno, NV
I think I used a combination of a flex head ratchet, deep socket, and a short extension. It was tight, but I didn't have any issue get all of the bumper nuts back on.
Sean
Maryland
Thanks. I got another bolt on this morning on the left side. Its the right side that is tight. My deep well 18 is to deep. Need a smaller one. I also read that buying a bolt without the flange should fit on the top right one. Ill keep at it.
cfree
Craig
Denver, CO
2005 LJ
Do the Warn winch synthetic ropes come with a nylon protective sleeve?
Derek
Derek
MA
2018 JL 2-Door
Mine did not, Maybe different on other models, mine is the EVO VR-10
quietpeen
Chambersburg, PA
2019 JLUR
On top of that the evo comes with the synthetic rope installed and the zeon does not which means you have to fight with seating the rope in the drum. Not nocking the zeon, i would love to have one.
hoag4147
Colleyville, TX
2022 JLUR XR
Thanks guys....Mine is the same way and was unsure about it, don't much care for it but it is what it is! I also put a cover on mine and what a PITA that is
Is this the Mopar Bull Bar/Grille Guard? If yes, any issue with space above winch controller?
hoag4147
Colleyville, TX
2022 JLUR XR
Clint54
Clint
Columbus, OH
2019 Jeep Wrangler Rubicon
It seems hard to view the line that is spooling onto the drum with this setup.
Has anybody had any difficulty observing the line spooling on the drum correctly?
