Warn VR EVO 10S & Warn Plate Install Pics
JL2021guy
JL2021guy
Daly City
2021 Jeep Wrangler rubicon 3.6
Jeep fun
I have the Mopar Grill Guard and a Warn winch with no problems at all.
How did you get the wire through the left side of the winch box?. Did you cut the plastic and use grommets ?
jeepdriver99
JD
Central Ohio
18 JLR 2 Door, 21 JLU TD, 06 GC, 54 Willys SW
Retired, W8BWD
No cuts to the plastic or grommets. I chose to go over the frame up front and run the wires along the frame. I hope I can explain how I did it and you can follow with these pics.
The first pic shows the the wires going forward under the top of the bumper to the outside of the frame. The "red" wire is inside the black corrugated protector and the black is running beside the motor,
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics IMG_4320
The next 2 pics show both wires on the outside of the frame.
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics IMG_4319
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics IMG_4318
I brought the wires up between the battery and air box. I was concerned having a front end accident with the wires being "hot" so I installed a relay to keep the wire from being energized and a 300 amp (if my memory serves me right) on the positive side (just in case).
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics IMG_4321
nU7OuxIx
Chicago
2025 JLU Rubicon X, YJ, Impreza
I like your wiring job. I think I did OK on mine but I feel like the area behind the battery is starting to get a little overcrowded. I bought a manual breaker switch because I didn't want it hot all the time to the winch.
If I may suggest, I would recommend getting little rubber boots that go over the positive bolts on your switch. They sell them on amazon and look like little spark plug/coil boots. I put them on mine along with some electrical tape. If that positive cable unhooks or hits something and grounds out, things won't be pretty.
99ls1tj
Georgia
2012 JK 2019 Ram 2500
Is that a EVO 10-s? It looks different than mine.
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics jt winch side
CaptStarboard
Australia
www.brisbanejeepclub.com
2020 Jeep JL Wrangler Rubicon 2.2L TD - "Jacko" Punk'n Orange (Old - 2010 Jeep KK Cherokee)
I think I used a combination of a flex head ratchet, deep socket, and a short extension. It was tight, but I didn't have any issue get all of the bumper nuts back on.
fun trick for evil bolt/nut installation is to use sticky tape to attach the nut to the socket, or tape the nut in place. Then when you push the bolt in, the nut is already in position and pierces the tape as it engages the nut. I've also wrapped a zip tie around a nut and used the tail of the zip tie to hold the nut up into an awkward position.
Getting ready to install a Warn Evo on my stock Rubi bumper, so appreciate all your learnings on here!
Cheers,
CaptStarboard
Chile1
Missouri
2018 JLUR & 2016 BMW X5M
Biotech Sales Management
What plate are you using? I used the Warn plate, and my wires are pressed super tight to the bottom of my grill.
same here because i too used the Warn plate.
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
Thinking I might upgrade to the Zeon as it has internal bus bars....however I see in other threads that some people have issues fitting the Zeon between the frame rails....
I wish there was a way to get an optimized winch plate for each winch. If the holes were 1/2 inch forward then my VR EVO would fit fine...
Murphydog
Seattle
Jeep Driver, how did you get the wires to come out of the side of the WARN control box? All the VR EVO 10s that I have seen have the wires exit the rear of the controller it mashes the wires against the grill.
LCW
Twin Cities MN
'19 4R TRD (gone '22 JLUR) (gone '23 Bronco BL 2d)
I dremeled the cover a bit and reclocked the wires so they didn’t press into the grille. Just need to get a harness sleeve to cover they up a bit.
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics 3FEB71CB-916E-4A55-A7C4-B77413BD6C9B
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics 64A5423E-02F0-4F42-9925-EE2C49829094
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics 27D7605D-8112-41EE-8E1C-5EE412A36DFF
Jeep Wrangler JL Warn VR EVO 10S & Warn Plate Install Pics 2743E124-A4B2-4E60-93C0-2899F265A879
