Vendor Options for UD60 steering?
WashingtonWetWheeler
Andrew
Marysville, WA
21' 6spd JLUR. UD60s & 40s
Just pulled the trigger on Spicer 60s, however I'm starting to worry I won't be able to steer them as RPM is out of stock, Fusion 4x4 is out of stock, and everywhere else I look doesn't seem to have an offering for this axle and a JL. Can anyone point me in the right direction? Much appreciated
Andrew
Marysville, WA
How about this, can anyone verify that all the UD60 steering for a JL is: JK length tie rod and drag link with JK ends on 3 of 4 locations with the exception being at the pitman?
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
based on the lead time for the JK replacement rod ends for the RPM being back ordered and all of the JL stuff being 2-3 weeks and the only jl steering kit on back order is the dynatrac and U60 kits i would assume that most if not all the axle aside is using JK parts. I would say give RPM a call and figure out what rod ends you need.
You are in pretty deep in the custom steering realm and most places do custom steering builds, for them its just a matter of how long to cut the tubes and what rod ends to put in the box
other options:
https://www.tmrcustoms.com/collections/jeep-jl-off-road-parts?page=2
https://www.rustysoffroad.com/rustys-aluminum-hd-steering-system-jl-wrangler-jt-gladiator.html
https://doetschoffroad.com/t/steering
custom links: https://www.wideopendesign.com/aluminum-links
Andrew
Marysville, WA
other options:
I agree and I've started a conversation with TMR to this effect. I just need to know what the dimensions on the tie rod and drag link are. Anyone know?
