Vehicle Shuddering in Reverse
AdventureTime2.0
Ca
2020 JLUS 2.0T
When I back up the vehicle shudders, is that normal? It's especially noticeable when turning the wheel which I assume to be related to the power steering system. Not sure if that's a common issue or not.
running_man
Andy
2019 Rubicon JLU, 2003 BMW Z4, 2012 Lexus ES350
I've never experienced that with my 2019 JLUR....perhaps something with your E brake sticking?
JerseyJeff
New jersey
2022 jeep wrangler rubicon extreme recon
Do you have a manual or automatic? If manual you could have a pressure plate issue. If automatic that's not normal and you may need a new trans.
AdventureTime2.0
Ca
2020 JLUS 2.0T
I tested it, seems to be while turning and backing up so my guess is a power steering issue while in reverse. Also, it's an automatic.
Heimkehr
Pennsylvania
2021 JLU 2.0T
No. It's neither normal nor common.
A bit of due diligence might get you closer to confirming the source, if not the resolution.
-Are the fluid levels correct in the power steering reservoir, and the transmission? The former is confirmed via an easy peek under the hood. The latter is checked within a narrow temperature range. See this thread for additional intel (start at #16.)
-Can you isolate where on the vehicle the shuddering is most evident? E.g., in the area of the front axle, or along the frame rails in proximity to the transmission body?
-A silly question, but we're just getting this one out of the way: Is the vehicle in 4WD when reversing?
Hope you can get things reconciled.
Nik H
Nik
RI
2018 Jeep Wrangler Rubicon JL
Does it happen in 4W HI or 2W mode?
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
Does driving at different speeds make a difference? Maybe try backing up at 5 mph, then 25 mph, then 50 mph, then 70 mph. Report back.
Disclaimer: I am not a transmissionalist.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
I'm most interested in the results of backing up and turning at 70 MPH. This will certainly reveal a problem.
/S This is satire. Don't do it.
AdventureTime2.0
Ca
2020 JLUS 2.0T
I'm new to jeeps so I'm still learning the quirks. Got my Rubi takeoff ready now just waiting for wheels and tires.
