V6 versus 2.0L V4 updates?
NAZJeeper
Woody
Northern Arizona
2015 JK
First of all, yes I did a bunch of searches and the newest thread is from last year (let me know if that is incorrect :)
As I get ready ( a week away hopefully) to pull the trigger on a new (used) JL, I keep going back and forth...at first I wanted the 2L because of the mpg and the extra pep, but saw a mention (forget where) that they were fussy and watch out for Turbos and all that. So the I started looking at only the 3.6 Pentastar, after all I've had 2 of them with few issues...well one blew a cylinder but got fixed under warranty.......
Question is - all things being equal, are they both worth having? Does the newer 2L have enough miles on it (100k+) to really form an opinion yet? Should I just get the Jeep that best fits my criteria and say to heck with the engine?
TIA and let me know if this info is somewhere else.....
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
50k on my 2.0T with zero issues. Great engine/transmission combo. The ZF8 is top notch and they are paired perfectly. In a 2 door the turbo is a rocket off the line and great off road with a really usable torque curve.
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
I second what speed331 says about off the line launches. My wife’s 2 door is a freaking hoot to drive. My 4 door with the turbo is still a blast but of course it’s bigger and heavier. It doesn’t have that go kart feeling.
Obi Wan
Obi
Tatooine, Outer Rim
starwars.fandom.com
2023 JLU SPORT S 2.0, 2004 TJ SPORT 5.3LS
Jedi Knight
The 2.0 is a I4, not a V4.
NAZJeeper
NAZJeeper
Woody
Northern Arizona
2015 JK
  • Like
Reactions: J0E
jayjc08
Jason
Ithaca, NY
2023 Jeep Wrangler Sport 2 Door
I'd also like to hear from long term (100k+) 2.0L turbo owners. Any out there?
Whiskeyxr
northeast
wrangler
our jluw is an xr with the 2.0. 12k miles and GREAT so far. Hope it stays that way. Coworker has jlur with 2.0 with 100k. Only problem was on oil leak early on and that was covered. His was the deciding factor for our choice. We have seen a few cash back offers recently but they are different depending on location. Good luck with your choice whichever way you go
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
Asking for anecdotes won't give you accurate data. According to my nephew who has written analytic software for used auto loan companies, they're both very reliable, although most data is less than 80K miles. I disagree with ChatGPT on the 3.6 better off-road if you have an AT. Here's what she says:
Both the 2.0 turbo and the 3.6 engines available for the Jeep JL Wrangler have their own unique benefits and drawbacks. The best engine for you will depend on your individual needs and preferences.
The 2.0 turbo engine offers more power and torque than the 3.6 engine, with 270 horsepower and 295 lb-ft of torque compared to the 3.6's 285 horsepower and 260 lb-ft of torque. It also has a better fuel economy, with an estimated 23 mpg combined compared to the 3.6's estimated 20 mpg combined.
However, the 3.6 engine has been used in Jeeps for many years and has a proven track record of reliability. It also offers a smoother and more traditional driving experience, which may be preferred by some drivers.
If you plan on doing a lot of off-roading, the 3.6 engine may be the better choice, as it has a wider power band and is better suited for low-speed crawling. However, if you value power and fuel efficiency, the 2.0 turbo engine may be a better option.
Medsker
Jon
South Jordan, Utah
Retired Engineer
I have a 122,583 on my 2.0 with e-torque. At 16,934 I got the blue screen of death on the radio instead of the backup camera that they had to fix with a computer update and at 36,349 I had a hose clamp that needed to be tightened on my water pump. It has got hot a couple of times pulling a trailer up steep grades on the freeway but has never overheated completely. It has a 2" lift and 37's and is an auto. It is as fast as I'll ever need it off the line and does great off road. I've had it all over Moab and never had so much as a glitch out of that engine/tranny combo.
