Upgrading Non-Alpine Audio
chuck_tempe
Chuck
Tempe, Az.
2018 Red JLUR 2010 Black JKU
Here's a pic of the rear area. 10" powered Fusion sub and on board air system.
The onboard air is a Viair 400 compressor with a Viair 1 gallon tank. I have a manifold, relay and pressure switch so it will pressurize the tank to 105 psi before it shuts off automatically. It will fire back up if it drops below 85 psi.
Jeep Wrangler JL Upgrading Non-Alpine Audio IMG_5133
cmb396
Chad
WV
2018 Crystal Granite JLUR
So I went with a JL 8" powered sub on the tailgaite, and it sounds amazing. A 10 will fit, but felt that it would interfere with cargo too much. Wish I would have know about the speaker change in the JLs when I ordered mine.
I knew I could get a helluva lot better stereo aftermarket for $1500 vs the alpine. While the alpine sounds good for what it is, it's no aftermarket JL set up.
I am just having a JL amp put on the factory speakers, and will replace the dashes with 3.5's, and wait for a JL plug and play for the sound bar to hopefully come out in the next few months.
bru22
bru22
Greg
Issaquah, WA
www.gbpro.net
2018 Jeep Wrangler Unlimited, 2016 Audi Q5, 2016 GMC Denali 2500HD
Principal & Creative Director
That is killer. Great idea. Any tips you care to share? Where did you get your preamps? Please share anything you have that can help - I am dying to get some better sound! This looks like a great option.
BlairF
Blair
Humble, TX
2018 JLUS-S Mojito! - 2014 Challenger RT Classic (SuperCharged) - 2016 Dodge Durango RT
Technology Incident Management
Heck yeah, that looks like a winner!
cmb396
Chad
WV
This box has an amp in it. The cost was $399 at my local audio shop. I will say, I had my doubts, but it really thumps for an 8" sub! As mentioned, a 10" box will fit as well, but it's about 3" deeper into the cargo area. This one doesn't really protrude out further than the door lock/handle interior offset.
The base is amazing out of this little thing!
The Jeep is in the shop now having a JL amp wired to the factory speakers, I knew nothing about the speakers changing!!
I've always been an after market JL or Wetsounds guy so didn't order my JLUR with the alpine and am now seeing the issues with upgrading speakers.
As for mounting this box, if you pull plastic interior cover off the inside of the tailgate, there are 6 mounting holes, just pre drill your box to match those mounting holes and bolt it in. Solid as a rock on the tailgate.
There is zero vibration with the tailgate latched, but some slight vibration with the tailgate open.
Let me know if y'all need any more info.
bru22
bru22
Greg
Issaquah, WA
www.gbpro.net
Where did you pull from the signal from?
I assume the rear speakers, but where at exactly?
Where did you pull the remote wire from?
Did you run a bass knob?
Any pictures of how/where you ran the wires for power?
Where did you ground the amp?
cmb396
Chad
WV
No clue man, had my local audio shop that does all my installs do it. I'll ask him tho and try to get ya some info.
cmb396
Chad
WV
Ok, remote lead came from the fuse box. Power wire came from under the battery. Signal came from rear speakers, pass side B pillar.
That box I have does signal sense and doesn't need a remote wire, and he just grounded it to the chassis.
Hope this helps.
BlairF
Blair
Humble, TX
Hope this helps.
I might very well steal this idea. :)
Drumpkins
Tanner
Georgia
2018 Wrangler Unlimited Sport
Just ordered the 10" today along with the remote knob.
Thanks for the idea!
cmb396
Chad
WV
The 10 will absolutely thump! I have heard it, and it sounds amazing. I was really surprised how well the 8 performs too!
Drumpkins
Tanner
Georgia
I'm just excited to take bass out of the sound bar. I cringe every time the speaker casing vibrates.
The only thing I am concerned with is it getting wet. I might look into options for some sort of weatherproofing.
ChattVol
Tennessee
JLU 4 door
Did you consider mounting this under the driver seat or rear seat to conceal it?
ChattVol
Tennessee
JLU 4 door
Hope this helps.
Just was quoted $275+tax to install this 8" jl audio sub to tailgate like yours. They highly recommended a separate bass knob be added to control the sub volume seperate. This price includes 8 gauge wire and bass knob drilled on front dash. Is the bass knob needed?
ChattVol
Tennessee
JLU 4 door
See post above...any thoughts are greatly appreciated.
