Typical after purchase 2024 Willys changes
Robere
2024 Willys 2 door 3.6 auto
On a 2024 Willys 2 door, 3.6, auto: are there any non-cosmetic upgrades you find essential or desirable? Of course if the bumpers fall off or are damaged I would opt for steel. Your thoughts?
gdeyarmond
San Dimas, CA
20 Tacoma 4x4 (6mt), 24 JLU Willys (6mt)
We put on Apex Autolynx Sway Bar disconnects and changed the shocks to Bilstein 5100s. Here are the links on Northridge 4x4
https://www.northridge4x4.com/part/...e-autolynx-sway-bar-disconnects-8-00in-stroke
https://www.northridge4x4.com/part/shocks/33-316321-bilstein-b8-5100-shock-absorber-rear-1-5in-lift
https://www.northridge4x4.com/part/shocks/33-316314-bilstein-b8-5100-shock-absorber-front-1-5in-lift
Robere
Robere
A Willys or ?
Robere
Why did you change shocks and disconnect? Off-roading or ?
gdeyarmond
San Dimas, CA
The disconnects came first. It's so nice to have the extra articulation even on easier trails when you're just hitting wash outs at speed there is no more head toss.
The shocks came after because when just cruising through small whoops and wash outs with our new found articulation and lack of head toss (the sway bar disconnected), the red 2024 Rubicon/Willy's shocks couldn't keep up and started to fade badly. Every single bump was ending with the Jeep hitting the bump stops hard.
It depends on the type of wheeling you do or will do. For sure, sway bar disconnects make a huge difference. If you aren't driving at speed a lot on trails or in the desert, shocks might not be as much of a necessity.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Essential or desirable for what?
An air compressor is typically my first recommendation if you plan on doing trails.
