Two USB-C ports on dash MOD?
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
I haven’t owned a USB-A device in years. All my devices are USB-C.
Is there a mod to replace my USB-C/USB-A ports on the dash with
USC-C/USB-C ports?
I am not a fan of Accessory Port adapters, or any USB-A to USB-C adapters, etc…just checking if the USB-A port can be removed and replaced with a USB-C port.
Jeep Wrangler JL Two USB-C ports on dash MOD? IMG_5293
Jeep Wrangler JL Two USB-C ports on dash MOD? IMG_5294
Jeep Wrangler JL Two USB-C ports on dash MOD? IMG_5296
donmontalvo
donmontalvo
Don
Livingston, TX
donmontalvo.com
agentdr8
CA
21 JLU Willys
The other easy method is to get a USB-A to USB-C cable.
AFAIK, nobody makes a replacement media panel with 2 USB-C ports. If you're handy with electronics, you could probably swap out the USB-A port with a USB-C port, but would likely require some customizations.
BXFXJeep
Toronto, ON
2021 4xe Sahara
It probably much easier and practical to locate the other 3 USB-C ports closer to the driver than modifying the dash A to C.
shane h.
Shane
DFW
'19 Mojito JLUR (mine), '21 Hellayella JLUR (hers)
Husband, Father, Papa
My plan is to put one of these up in the top of the dash in that little cubby. I need a USB-C outlet up there to power my tablet running GAIA when I'm traveling/off-road.
Jeep Wrangler JL Two USB-C ports on dash MOD? 771b8b3c73240ba_lg
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Nice, I did a similar mod to my old YJ.
@donmontalvo nobody makes a direct swap for that spot. Your only choice is adapters or to make your own hole and use the one above.
donmontalvo
donmontalvo
Don
Livingston, TX
donmontalvo.com
Per @THAW the connectors that plug into the back of the media hub are micro USB. And his pic in case it helps
I had my console panel removed earlier today and noticed the Mini B plugs. My goal is to swap out the USB-A port for a USB-C port, without losing CarPlay capability on the top (“#1”) USB-C port. Wireless CarPlay is a joke from what I’ve seen.
I think I will run a Powerwerx dual USB-C QC 4.0 connector to the front of the center console storage area, facing the cupholders. Will post whatever I come up with.
On a side note, funny how you seem to have your Accessory Port wire taped off with blue painters tape. I removed my Accessory Port so I could install the Redarc dial…but I used black electrical tape to isolate the same wires. :)
donmontalvo
donmontalvo
Don
Livingston, TX
donmontalvo.com
I did this.
It has 2 usb-a ports and 2 usb-c ports
Gregj
Nice, and clean! Unfortunately I have my Redarc brake controller dial there, so I can always glance at it.
