Two Complaints with Tazer JL Mini
sixspeed
Gregory
Arizona
2018 Wrangler Sport S JL
I have a 2020 JLUR. I have used a Tazer JL Mini for around two years. It generally works fine but there are two things that annoy me.
1. About every 20th start, the ESS will not stay where I left it--which was off. I manually turn it off and then it stays off for around 20 starts then doesn't, etc. I haven't counted stops but it seems to be around the same period of time each time
2. I use a hot key (up arrow on the cruise control) to disconnect and reconnect the sway bar. Lately, when I have reconnected, it takes a long time--2-3 minutes.
Any comments on these problems? The first one is minor and I assume a glitch. With the sway bar, I fear one day it won't reconnect and I'll have to deal with that.
TEAMSLO
North Las Vegas
23 392, gone 21 JTM & 22 JLURD
Just my $0.02 here
1 - I don't have this issue but like you mentioned, wouldn't be a big deal if it were there.
2 - You could get an antirock or another type of setup, if I would have kept the factory sway, I would have gone the evo knob route to avoid it reconnecting when it does. Easy enough to manipulate during air down and up.
Terrymo
Terry
2023 JLURXR 3.6 ET
Besides posting here I would text Tazer tech support (Text Support: 833-432-3549) I have a few times and have gotten a response within 24 hours including on a weekend
1. I have only had a Tazer JL mini for a year but have never had this happen
2. What leads you to believe the swaybar disconnect/reconnect issue is the Tazer rather than
what it’s controlling?
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
No issues with 2019 Rubicon v6 auto. Try the recent firmware update and do the full reboot close door and walk away for 15 minutes for system to sleep and come back and open door. Close door again and wait for sleep cycle. Everything should function proper.
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Unmarry the Tazer, remove from Jeep, try updating the firmware, then plug back into the Jeep and set it up.
Sway bar isn't a Tazer issue.
jharp
Justin
Kitsap County WA
2025 JLUR, 2024 JT, 2025 R1S
I had very similar issues when I had the Tazer on our '23 JTRD, I updated it when I moved it to my wife's JT, and the problems went away.
Not sure if it just "works better" on the new JT, or if the firmware update helped, but it's worth an update to see if that solves it.
RubiSc0tt
Upstate NY
2019 JLUR in Punk'n Orange
Turn Wrenches/ Write code
2019, V6, Manual Transmission, Tazer.
I've had Tazer installed since 2021. I occasionally have that ESS glitch. I just press the button and go on my way. Doesn't come back consistently. Definitely weird.
