Acourvil
- Art
- Mar 16, 2024
- San Jose CA
- 2019 JK Sahara
Is there any way to turn off the ESS warning light? I know you can get ESS dongles that let you automatically set the ESS off switch, but is there a way to eliminate it completely? (Pushing the ESS off switch does not clear the warning light).
Apparently, a connection in the ESS wiring somewhere under the car disconnected and the plug has been damaged. I have been told that in order to fix it, the wiring harness needs to be replaced. However, I don’t like ESS anyway and am happy to have it permanently off. the only problem is that the warning light is on and I get a warning that the system isn’t functional when I start the car. Is there a way to eliminate the warning messages and warning light? Everything else is working just fine.
This is a 2019 Jeep Wrangler Unlimited Sahara, automatic transmission.
