RubiRob
- Rob
- Feb 14, 2018
- Hampshire, IL
- Website
- www.instagram.com
- Mojave
- Vehicle Showcase
- 1
Hello all,
I've recently hit my breaking point with this ESS stuff. I honestly don't care that it doesn't work very well if not at all but I don't like that my batteries are in a constant state of low charge even if I drive 1hr a day.
-18' JLUR build date 12.17
-No electrical mods other than relocating 3rd light and plate light. Have a winch but that has ruled out.
-I've replaced both batteries they've both been verified by Jeep and Orielly's that they are fine
-Orielly's verified Alternator is working fine
OK so with that being said, Ive been dealing with the ESS being on and off for over a year, but within the last 6 months it just hasn't worked at all. I've never had an issue such as a dash light or dead batteries, just ESS not working for the longest time. Currently I need to drive for over an hour for ESS to be "ready." The Batteries are 3 months old, one is a direct replacement AUX and the other is an Optima yellow top that has a Higher CCA rating than stock. The volt page 99% of the time is 14.6 and 14.7 no matter if ESS is working or not. If I trickle charge the batteries all the way, the volt page displays normal numbers and moves up and down as I drive properly. A day or so later, it will be back to that 14.6-7 number. When ESS does activate at that 14.6, the volt page will drop down to 12.2-12.6 and then stop for a second. After that second goes by, the voltage drops by 0.1 every second on the second until it gets to the mid 11.x and the light turns green.
I finally got this to a dealership (3 other local dealers were / are a complete waist of time so I had to go to one 45 minutes away) the other day. Explained everything and they had it for about 4 hours while I waited. They said that the batteries and the IBS were all functioning normal and that "this really ends up just being a waist of time for the customer and the dealer as this is such a common problem." He suggested that I just live with the ESS not working properly as its so common. I explained that I don't care about the ESS as much as I care about the batteries being constantly discharged and then recharged more than normal. He seemed to understand but offered no other help. I asked if they could perform a test to see if something is draining the batteries and he said they could but it would carry a $160 diagnostic fee because I "replaced the OEM batteries." I plan on calling him back and insisting that he does it for free, since I am still within 3 years and 36k miles. He did say something about taking a look at the batteries again next week when I drop it off for other work, saying something about a "battery history" that the tech would be able to look at after they fully charged them.
-Does anyone have an suggestions on what I can do or what test I can perform myself to fix this issue?
-How do I do a parasitic drain test on the dual battery system properly?
-Has anyone had one of these problems that wasn't caused by the battery/IBS/Alternator?
Added a photo from my drive today showing 14.8v on the way to get groceries. This photo was not even 48hrs after the Jeep dealership had fully charged up the batteries. Hope to get @JeepCares in on this as well.
Thanks all!
Thanks all!
