Transfer Case setting
mikedibilio
Bethlehem, PA
2020 Rubicon Unlimited JL
High School Administrator
I am running 35s on my 2020 jLU and using a flashcal I have set my gear ratio at 4.56 (thinking of going to 4.88). What would you recommend that I set my transfer case at. At the current time, I am at 2.72 right now.
mikedibilio
mikedibilio
Bethlehem, PA
Have actually replaced your differential gears? If so with what ratio? You can’t just program ratios without having physically replaced gears.
I will be the very first to admit that this is totally outside my wheelhouse. But, my Rubicon has the stock lift that comes with it, and I increased to a 35 tire. I was told that I would not have to actually replace the gears unless I were to go with bigger tires (which I wont be doing). Any guidance here would be greatly appreciated.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
You have a Rubicon and have your transfer case digitally set to 2.72:1?
...Why?
You have a 4:1 transfer case. Set it to 4:1.
Also do you have 4.56 gears? Or 4.10s?
If you have the (usually 4.10) Why do you have it set to 4.56?
mikedibilio
mikedibilio
Bethlehem, PA
As I said, I am far from a "motorhead" here, so I am looking for advise from people with the expertise.
azwjowner
Phoenix
You're way down the wrong path here. Unless you physically changed the gears in your axles, that setting needs to be reset to factory -- what gears your Jeep actually came with.
Unless you physically swapped your transfer case (and it would be nuts to do so, because the 4:1 transfer case in the Rubicon is much better than a 2.72:1 case in the Sport), that setting needs to be reset to factory -- the 4:1 that your Jeep came with.
If you put larger tires on, the tire size setting is the only setting that you should change. That tells the Jeep computer what circumference your tires are, so when the sensor sees one revolution, it knows how far you've traveled (and what speed).
mikedibilio
mikedibilio
Bethlehem, PA
Ok, this helps. When I reset to factory settings though, the gear ratio (2.73) is the one highlighted on the flashcal screen?
KevinC11
Kevin
Central Florida
2022 JLU Willys, 2023 JT Mojave
Gunsmith/EMT
You are confusing us along with yourself.
With a Flascal, reset everything you messed with back to factory. If the transfer case was originally on 2.72, put it back.
Measure your tires under load. A 35" tire (depending on Manf) should be around 33.9-34.4 inch. Either measure up halfway ( ground to centerline of the hub) and x2, or just measure ground to top of tire.
That is the only value in Flascal settings you should be changing.
KevinC
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Set all the settings to what you have, not what you want them to be.
Then drive down the interstate and verify that your speedo matches what sometimes like Waze / Google Maps says.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
You have a Rubicon, 2.72 on the transfer case is wrong. Gear ratio for axles should be 4.10:1 and transfer case 4.0:1
58Willys
Geoff
Western Washington
2018 JL Sport
If you actually replaced the original 33” tires with 35” tires, then reprogram the tire size. Do not reprogram anything that you did not physically change. Reprograming parameters are to tell the computer that you have physically charged something, such as differential gears, it’s not for what you want.
