Trans kit 8 speed
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
@CarbonSteel
I wouldn’t mess with anything other than ZF/OEM.
CarbonSteel
Blauparts is a top notch company and they typically specialize in selling Ravenol products which are also top notch.
Eurol is regarded as decent in Europe typically made in the Netherlands which has good quality controls.
With all of that said, I would only use Mopar filters and either ZF Lifeguard 8 or 9 fluid or Mopar 8 & 9 fluid only in these transmissions.
Here is a post I created detailing the how to:
https://www.jlwranglerforums.com/forum/threads/zf8-50k-mile-transmission-service.94302/
Stuckinthesand
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Thanks for the advice. I was leaning towards ZF/Mopar parts but this popped up when I was searching for a kit.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
What about the fluid in the converter and valve body?
GATORB8
CLT NC
More expensive than the ZF fluid that Carbon posted, but looks like the best price I found on the Mopar stuff was Rock Auto.
Stuckinthesand
Stuckinthesand
CJ
NJ
I went with @CarbonSteel links and ordered the fluid and filter. Haven’t decided if I will do multiple changes yet. If it takes 5 1/2 quarts that’s a little over half of capacity. I may let it ride like that for another 60k. Looks like his UOA was good on the factory fill and leads me to believe changing just the pan fluid will be ok.
CarbonSteel
Do you recall what torx size was needed for the pan bolts and the drain plug were used?
The fill/drain plug is a 8mm hex (allen style), the pan bolts are a Torx and <edit> it is a T40.
CarbonSteel
The fill/drain plug is a 10mm hex (allen style), the pan bolts are a Torx and I want to say it was a T25 (could be a T35). I can check that one and let you know.
@Stuckinthesand - you need a T40 Torx for the pan bolts. Retorque to 10-12nm (I went to 11). The fill plug is an 8mm hex (not 10mm as I stated above).
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
