Trailer - Where to Start
treillw
Montana
Jeep Grand Cherokee
I'm contemplating getting a trailer to pull with my 2022 JLURD. I'd like to get a new vehicle for 1000 mile trips that I make for work pretty often. Trouble is a truck with a camper cap is required for my lifestyle - filling up the entire back with camping gear and hunting "trophies". I don't want to sell the Jeep, for obvious reasons, and we don't need a third vehicle when we hardly use the two we have. We both work from home, with the exception of my work trips.
I'm thinking of selling the truck and buying a trailer and fuel efficient vehicle - that might give us the best of both worlds without the expenses of three vehicles.
Any suggestions on a trailer? I started searching around the internet and there seem to be a ton of options. Some of them are $40k+ which isn't going to help me in the money savings department.
Initially, I mainly want it for transporting camping gear and elk/deer from hunting trips. Then I'm looking the ones they have with kitchen areas, showers, and rooftop tents - they are very nice but seem very expensive. Other possible future uses would be for transporting a side by side. I'd like to take it on some pretty rough Montana roads into remote areas, but I'm not going to be going up huge rocks in Moab - don't know if a normal ball type hitch will work.
Any suggestions on what to look at that isn't $25k+? Ideally $10k might be reasonable, but I'd really like it to be less than that. I appreciate the ideas.
Thanks!
C.Sco
2023 4xe Rubicon
After going back and forth with myself about this as well, weighing the different options from a basic cargo trailer to something fancy that even throws in literally the kitchen sink, and at this point I think I'm leaning towards something super cheap and basic like this:
Jeep Wrangler JL Trailer - Where to Start bMRkZsD
And then upgrading the wheels and tires and buying or making some sort of cargo basket for it.
ArmyRN
Paul
Longview, WA
1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
Yes - build your own off a HF trailer frame. That's what I did.
Here's a very long thread I started (with lots if input from others) regarding building a little expedition type trailer off a HF frame. The frames can be narrowed and shortened easily.
Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread | Jeep Enthusiast Forums (jeepforum.com)
I would suggest you get comfortable and sit down and read through the whole thing. It is very long, but once you're done reading it, you'll be ready to build your own. It can easily be done for a couple thousand dollars at the most. Here's mine:
Jeep Wrangler JL Trailer - Where to Start arctic prerun.2
Jeep Wrangler JL Trailer - Where to Start CA pre-run.2 (3)
Jeep Wrangler JL Trailer - Where to Start Arctic Trip.3
That's a double-sized Cabela's Tent Cot on the roof of the trailer. 3500lb axle with electric brakes, real leaf springs vs. slipper springs, etc. etc. etc. Someone else made the tub for me (it is just a box with a hinged lid - nothing fancy). If you can do a Jeep suspension lift, you can build a trailer for off-road/overlanding.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If you decide to go back to the toy hauler/camper style. Some to look at would be inTech's Flyer, Forest River No Bo, Rockwood Geopro.
On the utility side, check out Northern Tool's selection. They have basically the same folder as HF, but they also have some beefier stuff for not too much more. https://www.northerntool.com/categories/trailers
For the most part, the utility range won't be bad to modify suspension and hitch wise. If you get a little heavy, I'd at least grab one prewired for brakes.
C.Sco
2023 4xe Rubicon
^ @ArmyRN That trailer is epic!! Great job!
Rustynail11
Mansfield, TX
2022 Wrangler JLU Rubicon
I bought one of these about 10 years ago when I had my first JKU and was doing a lot of camping trips with the family. I decked it and built side rails. It is a great little trailer and hauled my camping gear all over TX for several years.
driventoadventure
Lrr
Northern Front-Range, Colorado
21 JLURD
Employed Gainfully
The Jumping Jack trailers are a good combination of utility trailer and tent trailer... https://www.jumpingjacktrailers.com/. If you're more looking for a luxe trailer though, you're going to want a tent trailer and those won't have a lot of trophy storage...
treillw
Montana
Jeep Grand Cherokee
Excellent ideas. Thank you. Keep them coming.
Valpo Jeep
Doug
Valparaiso IN
What to get depends on how you are gonna use it. If you plan to go to a campground and then go off-roading from there then perhaps a travel trailer or an RV. RV route you can flat tow the Jeep. Plenty of room for however you want to camp. If you go travel trailer route then you are some what limited in size to drag behind you.
If you are looking to get out there off the grid in the back country then one of those off road trailers would work. You will be a bit more limited in what you can carry back with you.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Av8Chuck
Chuck
Thousand Oaks, California
2020 Rubicon
Jeep Wrangler JL Trailer - Where to Start IMG_3892 2 Lar
Jeep Wrangler JL Trailer - Where to Start IMG_3893 Lar
Jeep Wrangler JL Trailer - Where to Start JEEP TRAILER-2
Jeep Wrangler JL Trailer - Where to Start JEEP TRAILER-3 Lar
I still need to paint and mount the RTT and awning on the trailer. It has solar, camp kitchen with DC Fridge, running hot water, 20 gal water and gas, and a hot shower. I don't do hardcore rock climbing but getting off grid can get a little technical so you have to plan on rolling the trailer. You need to be able to winch it back on the wheels and continue on.
