What pressure does it like? If it’s like the JK probably 31 or 32psi.
What happens when you go to 35s or 37s and run lower pressure. If you’re running lower than the recommended PSI (which you have to when running big tires) it will trip the id10t light on the dash.
What happens when you deflate, but are in 4 high? Then 4 Low? It doesn’t matter if you’re in either 4HI our 4low, it will still show the warning light.
