TPMS
Stickerhead
McKinney, Texas
2018 JLUR, 1997 TJ on 37’s, 2017 Powerstoke Tow Pig
Anyone know where the trip setting is for low tire pressure?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Stickerhead
I'm unclear what you are saying...
IF you are intentionally running lower tire pressures and this is setting off the TPMS low tire pressure warning, you can.... raise air pressure in the tires so warning stops or buy a programmer, which you would use to turn off TPMS or to change TPMS warning parameters.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
He's just asking at what tire pressure does the light come on. I have no idea what the default setting is.
WXman
Central Kentucky
36 PSI is spec on my Sport S, so I'm guessing that the threshold for throwing the warning would be somewhere around 32-34 PSI.
Kysport
Louisville
2018 Wrangler JLU Sahara
I’ve had mine to 30 and no dash light warning.
EsTxDr
Adam
2018 JLU Rubicon
Can you not set it to desired PSI? I dont have my JLU yet but my Colorado ZR2 allows you to set the limit for notification.
mwilk012
Oklahoma
Service
You need a programmer to set the TPMS light to a different value.
Stickerhead
Stickerhead
McKinney, Texas
I am testing the steering issues by lowering the tire pressure. Came from stealership at 41 psi. Lowered to 37, then lowered to 34. Drives much better but want to lower it more before buying a programmer. Just wanted to know where owners have seen the light come on. Looks like 29-30 psi from what people have posted
Thanks for the input
