TPMS sensor
danielw2085
Daniel
Alabama
2022 Wrangler Unlimited Sport Altitude
Does my factory spare have a TPMS sensor installed? I swapped my spare to my front driver side and my TPMS system light came on and stayed on in the instrument cluster and it is not reading the tire pressure on that tire.
Rico1111
Rico
RI
2018 Rubicon 2 door JL
It Should! Take it to the Dealer and have them install a new one. I'm assuming you are still under warranty. Although wait a few days ...it may take time to recognize. Mine is a 2018 and some items have changed like the tpms...check in settings for resetting them? just reaching, Like I said some things have changed with the newer JL's.
sailscall
Buffalo, NY
2021 2dr Sport 6MT
Did you drive it a few miles after the spare went on?
danielw2085
Daniel
Alabama
Yes I’ve driven it approximately 100 miles. It tool 20 or so miles before it came on.
Packnbeer
Jamie
Davenport, Iowa
2021 Jeep Wrangler Sport S 2-Door
it has to be programmed to the vehicle. There are only 4 TPMS locations on a wrangler and the spare is not one of them. When you put the original wheel back on, it will need to be programmed once again. They do not program themselves when swapping tires. If you rotate your tires, you also have to have tham all reprogrammed as well or they will not show in the correct tire location.
LCW
Twin Cities MN
'19 4R TRD (gone '22 JLUR) (gone '23 Bronco BL 2d)
it has to be programmed to the vehicle in the location it is being used. If you rotate your tires, you also have to have tham all reprogrammed. It was still probably reading the one you took off that I am assuming was flat and thats why the light is on.
Incorrect - they automatically get reconfigured to the proper corner. At least on my 22. Rotates stock tires with the spare. No issues. Bought new wheel/tire set with new sensors. Synced up automatically.
Some Random Guy
Washington
Comptroller
There’s a home reset procedure for when the auto detect messes up.
Copy/paste from @Goin2drt :
1. Remove the spare and leave it in the garage. (if the TPMS is awake it can foul up the relearn)
2. Lower your PSI 12lbs and go drive for like a block is all.
3. Come back and fill to exactly the door placard even if you are not going to run that PSI. Once relearned you can adjust to what you want as long as it is not 10% below door placard.
4. Go drive a few miles. All should relearn properly.
Packnbeer
Jamie
Davenport, Iowa
I was completely unaware that these sensors relearn. That is awesome info. All of my other cars all need to be reprogrammed when changing anything. Thanks for the info!!!
Some Random Guy
Washington
Comptroller
Theoretically. My Rubicon would randomize my tire location after each rotation, then throw TPMS errors because it was trying to read a tire that was across the Jeep.
danielw2085
Daniel
Alabama
Thanks I’ll give that a try!
danielw2085
Daniel
Alabama
Did it get resolved?
Nope. Totally didn’t work. Guess I’m going to have to take it to the dealership. I was trying to avoid that because it’s such a hassle.
rkwfxd
Rich
Whittier
2021 JLR, 2020 Tahoe 4x4, 2006 Tundra, 1990 964
Unemployed
Hmmm. I’ve had to work my spare into the rotation twice, once due to a torn valve stem on the trail and once during normal 5 tire rotation. Each time the cpu figured it out right away. 21 Rubi.
