Top speed in 4LO
Shu
Justin
ND
2020 Jeep rubicon diesel
Don't forget low range is also much lower in the Rubicon.
Not with the diesel models, they are not 4.1 anymore
Shu
Justin
ND
Where are you seeing that? The order guide only says that the full-time rock track is not available with the 3.0.
The rubicon diesel is only offered in the 3.73:1, I have one.
Bearded_Dragon
FL
2018 Mojito! Rubicon
When someone mentions, "low range" they're talking about 4L on the transfer case, which I believe is still 4:1 for diesel Rubicons. 4.10, or as you put it 4.1, is the final/differential gear ratio.
word302
Oregon
JLU
You are confusing able ratio with transfer case ratio. The transfer case is still 4:1 on the diesel so low range is still significantly lower on the Rubicon, just not quite as low on the diesel.
Shu
Justin
ND
Correct, I am talking about axle ratio for both gas and diesel. Gas axle ratio is 4.10:1 and the diesel is only offered in 3.73:1 axle ratio.
Shu
Justin
ND
Axle ratios available for each model:
2-door JL Wrangler Sport (2.0L): 3.45
2-door JL Wrangler Sahara (2.0L): 3.45
2-door JL Wrangler Rubicon (2.0L): 3.73, 4.10
2-door JL Wrangler Sport (3.6L): 3.45
2-door JL Wrangler Sahara (3.6L): 3.45
2-door JL Wrangler Rubicon (3.6L): 3.73, 4.10
4-door JLU Wrangler Sport (2.0L): 3.45
4-door JLU Wrangler Sahara (2.0L): 3.45
4-door JLU Wrangler Rubicon (2.0L): 3.73, 4.10
4-door JLU Wrangler Sport (3.6L): 3.45
4-door JLU Wrangler Sahara (3.6L): 3.45
4-door JLU Wrangler Rubicon (3.6L): 3.73, 4.10
4-door JLU Wrangler Sport (3.0L diesel): 3.73
4-door JLU Wrangler Sahara (3.0L diesel): 3.73
4-door JLU Wrangler Rubicon (3.0L diesel): 3.73
JT Scrambler Pickup Base (3.6L): 3.45
JT Scrambler Pickups Premium (3.6L): 4.10
JT Scrambler Pickup Base (3.0L Diesel): 3.73
JT Scrambler Pickup Premium (3.0L Diesel): 3.73
Shu
Justin
ND
As you can see there is no longer a 4.10 option for the diesel power tran
mgroeger
mgroeger
Southern UT
2021 JLUR 2.0T
I believe the 3.73 you are referring to is the gearing in the axles. The diesel Rubicons still have the 4:1 transfer case.
  • Like
Reactions: J0E
