Tire Wear Question
fastcar4re
Houston, TX
2018 JL Jeep Wrangler Rubicon
If I did not ever rotate the tires on my 2018 JLUR, always ran on-road in 2 Wheel High, would the front tires or rear tires tread depth wear out faster? I understand the front tire "edges" would wear from turning, but just regarding tread depth, which would wear out first? Thank you.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
The rear.
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
The rear but it would hardly be noticable unless you burn out all the time. RWD primary vehicles wear the rear tires faster, however, the front tires are handling the load for braking and turning - so any wear difference would be very minimal.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
Tread depth in the rear would wear quicker, as others have said.
In my experience, while not worn down, you're far more likely to get an abnormal/uneven wear pattern in the fronts before wearing down your rears, if you never rotate.
So keep that front end aligned properly to fight that uneven/abnormal wear.
WorkingMan
Tim
Arkansas
2019 Jeep Wrangler Sport S
A buddy of mine told me he never rotated his tires, and me driving Toyotas that need to be rotated every 5k at least, I didn't believe him. However when I got my Wrangler I tried it and sure enough, I have not once rotated my tires and they are wearing evenly. Solid front axle keeping the wheels level vs. independent suspension always pushing the toes in I guess.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
You're fine with replacing them 20% sooner?
WorkingMan
Tim
Arkansas
How is rotating them going to make them last longer when they are wearing evenly?
