Tire pressure
Van Halen
Danny
Mississippi
2021 Jeep Rubicon
Stock 2021 Rubicon - 25psi is that a proper air down tire pressure for most trails such as Blackbear, Imogene, Ophir, or the Alpine loop
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
If I air down it’s down to 18 lbs minimum If I’m going thru the trouble of airing down.
2 door, 4 door, armor or not, tire size, sand, rocks, mud etc. It all can change that number but 18 is an easy go to. Staying the upper teens and you will be ok as long as not taking sharp turns at 50mph.
kah.mun.rah
Merenkahre Jr.
Duat
Depends on if you have something to air up after. If so, I would say 17ish. If you have to drive on pavement a long distance to find air I would keep it above 20.
sunset
Jay
Seattle
1984 Camaro Berlinetta V8, 2024 Wrangler Rubicon 392
Wow, good practical advice. I haven't read of anybody saying that before. Thanks.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
You really shouldn't air down unless you have a compressor, which IMHO should be your first purchase.
Wbino
NJ
During a cold snap your psi will tank faster than your mpgs.
sunset
Jay
Seattle
More good advice, and Amazon told me my air compressor is on the way. My 392 is on the way, too.
AZ Hella
Sonoran Desert
JLUR
I run 18-20 for most trails and never had any problems crawling the rocks. If I'm putting down many miles on washboard roads I will go 15 for comfort.
kah.mun.rah
Merenkahre Jr.
Duat
Another thing to consider (especially at stock ride height) is that the less air in the tires, the less the ground clearance. Depending on the trail conditions you have to balance whether you want more clearance or more traction and comfort on the bumps.
Sand Flea
Kevin
Lewes DE
2025 JL Wrangler Unlimited, Sahara
Federal Firefighter, Retired
~18 to 19 while running on the beach.
Jeep Wrangler JL Tire pressure IMG_0466
Jeep Wrangler JL Tire pressure IMG_1542
JLeco2022
Anaheim, CA
2022 Wrangler 3.0 V6 Eco Diesel
12-15 psi for non-beadlocks, with locks as low as she lets me go, depends on what im trying to go up and I always air up before i hit pavement
Zandcwhite
Zach
Patterson, ca
2019 jlur
25psi isn't even aired down, despite what tfl might tell you. That's the cold pressure I set our tires to fit the street. They'll warm up to about 28-29psi on the street. The trails you mention I'd go down to 15psi. When we were in telluride we didn't air back up between trails. You can drive for short stints on the road at 15psi no problem. In moab I usually do the same. I'm not airing up and down 20 times over a week, no need. Mud, sand, snow I'll go down to 10psi without beadlocks. Airing back up for the road is necessary when you go that low. Telluride area trails aren't challenging so you don't need to go any lower for traction. Moab slickrock offers so much traction you don't need to go real low unless it's wet out.
