Tire pressure/s
Bullwinkle
Lyle
White city, Or.
2019 Wrangler Sport S
Without bead locks what seems an avg. safe low pressure so I don't lose the seal on the whole tire? I know the variables of that are mind numbing, just an educated guess might help me from disaster
entropy
Foothills of the San Gabriels
OF top 1% content creator
12 to 15 should be safe. Anything below that and youre risking it. Depends on the tire.
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
There are a few variables to consider. The volume of air is what supports the vehicles weight, so a larger tire can get by with lower pressure than a smaller tire. The stock tires on a JL Sport will require more air pressure than a typical set of 37s.
The speed the vehicle is going to be driven at should also be considered.
For the stock 33" tires on my JLUR I generally use these pressures:
For high speed desert (40 to 60 mph) I air down to 25 psi
For moderate speed (20 to 40 mph) I air down to 20 psi
For slow speed, or when I plan on being in low range much of the time I air down to 15 psi
Bullwinkle
Bullwinkle
Lyle
White city, Or.
There are a few variables to consider. The volume of air is what supports the vehicles weight, so a larger tire can get buy with lower pressure than a smaller tire. The stock tires on a JL Sport will require more air pressure than a typical set of 37s.
appreciated
