Ticking noise. Advice needed
Countryswiss
Devin
2018 Jeep Rubicon Unlimited
Jeep made this ticking noise for as long as I can remember, I’m at 33k miles now.
2018
Jeep JLUR 3.6
Is this normal ?
Countryswiss
Countryswiss
Devin
sound comes from passenger side of engine.
Engine runs just fine
TaiMc
Tai
Houston, TX
www.instagram.com
'18 JLU Sport Mojito!, 3.6L & '18 Ninja 400 KRT
Communications Manager
Are you able to check/look at your timing belt? IDK why but this noise reminds me of when my dad had me help him change a timing belt. It sort of sounded like this. I don't think this is a noise inside the engine, but it sounds like it's spinning...like a frayed belt or something. Just a guess.
I'm sure some of the gear heads will chime in soon.
flyer92
Nevada
I have this same engine in a Cherokee and Wrangler, and they both sound like yours. Normal, unless you’re seeing some unexplained change in performance.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
2018
Jeep JLUR 3.6
Is this normal ?
It sounds like loud injectors, but ask your dealer to inspect this.
It could be the beginning stages of a cam follower failure. Very common 3.6L failure.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
When port injection then direct injection first came out, the complaints about ticking went way up. Injectors can make a lot of noise. That's why plastic engine covers with insulation or foam engine covers came to be.
It could also be an exhaust leak. Check the manifold bolts, sometimes they come loose or even break. That would absolutely cause an audible tick.
https://www.chargerforums.com/threads/loose-manifold-bolts-on-3-6-pentastars.381841/
Countryswiss
Countryswiss
Devin
Just changed my oil with 5w30. Ticking is still present but it seems like a few of you say it’s normal. Any other input is appreciated, I’m going to try and find another person with a 3.6 so I can listen to their engine and compare
Countryswiss
Countryswiss
Devin
The timing belt is within the valve cover correct ? Not the external rubber belt ?
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Please get this inspected. If this is a cam follower failure, you’re going to destroy the motor.
