The reason for wheel spacers ?
Nardulli
St Louis
2021 JLU Rubicon Diesel
I see many rigs running spacers - or at least it appears to be the case. Wheels/tires way out past the fender flares. I get that the wider stance would increase the capability to be off camber before rollover - but is that the only reason for spacers?
Terrymo
Terry
2023 JLURXR 3.6 ET
Taller and wider tires on factory offset wheels may rub the inner fender liners with articulation or aftermarket front lower control arms when steering is turned to full lock. In my case 37 inch Mickey Thompson mud terrains with OEM XR wheels do both. I’m reluctantly running Synergy spacers until I buy wheels with a different offset.
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
Spacers may be needed when you put larger tires on to stop rubbing issues. Rubbing can be a problem when going to larger tires, bigger brake calipers, suspension changes, etc. The spacers can sometimes replace the need to buy new wheels.
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
Spacers are a poor boy’s offset to prevent rubbing.
Rather than pitch perfectly good rims, it’s more economical to simply install spacers.
Nardulli
Nardulli
St Louis
Thanks. Appreciate the info. My rig is a 2021 JLUR diesel. I've ordered the MOPAR lift kit which will give me between 2 and 2 1/2" lift. I've got 17" steelies coming. What would your suggestion be with regard to tire size? I'll put the larger tires on when off roading and swap the OE wheels / tires when using it as my daily.
yokramer
Snark Incarnate
What are the specs on the steel wheels you bought?
Spacers are for people too cheap to buy proper offset/width wheels.
Nardulli
Nardulli
St Louis
17 x 8 with OEM offset
Whaler27
Alex
Oregon
Saving the world :-)
I agree with the above. Also, a small subset of people think it looks “cool” to have their tires sticking far outside the fender wells. I think that looks as ridiculous as huge wheels with rubber-band tires stretched around them, but it seems to especially popular in downtown Miami and L.A., and it’s similarly counterproductive, with road grime, mud, and rocks being thrown all over the sides of the jeeps and trucks that are set up this way.
Jeep mods are like haircuts. Cool or circus-worthy, whatever floats your boat is fine with me. :rock:
People have the most amazing ideas about what looks good or “dope”. :CWL::LOL::LOL:
Jeep Wrangler JL The reason for wheel spacers ? IMG_2852
Jeep Wrangler JL The reason for wheel spacers ? IMG_2851
Jeep Wrangler JL The reason for wheel spacers ? IMG_2850
Jeep Wrangler JL The reason for wheel spacers ? IMG_2849
Jeep Wrangler JL The reason for wheel spacers ? IMG_2845
Jeep Wrangler JL The reason for wheel spacers ? IMG_2844
Jeep Wrangler JL The reason for wheel spacers ? IMG_2846
Jeep Wrangler JL The reason for wheel spacers ? IMG_2847
Jeep Wrangler JL The reason for wheel spacers ? IMG_2841
Jeep Wrangler JL The reason for wheel spacers ? IMG_2843
Jeep Wrangler JL The reason for wheel spacers ? IMG_2839
Jeep Wrangler JL The reason for wheel spacers ? IMG_2836
Jeep Wrangler JL The reason for wheel spacers ? IMG_2838
yokramer
Snark Incarnate
I'd stick with the 315/70 which puts you around a 35" tire, you could go to a 37/12.50 but could run into rubbing issues with fender liners, and FOR SURE will have issues running any aftermarket steering solutions as they almost all require a larger backspacing.
Nardulli
Nardulli
St Louis
Thank You.
yokramer
Snark Incarnate
Thank You.
What kind of wheeling are you planning on actually getting into as well. If you dont think you will ever be fully flexed out you probably can get away with a bigger tire than someone thats going to push the jeep a bit further.
jadmt
jeff
montana
slap some 1" BORA wheel adapters on and go with 37x12.5-17....I run two sets of tires/wheels...OEM wheels with 255/85-17 (35x10) and 1" BORA adapters for just running around and 37x12.5-17 on AEV wheels for offroading.....no rubbing on either and both are about even with the fender flares....I have had both sets to Moab and both do great but the 37's are game changers.
Jeep Wrangler JL The reason for wheel spacers ? tempImage3SsRHD
Jeep Wrangler JL The reason for wheel spacers ? tempImageF5tmyB
Nardulli
Nardulli
St Louis
I really enjoy the southwest / desert - some of the washes are moderate to difficult. I stay away from the (what I consider to be) useless abuse of the rig. Crawling extreme rocks aint my thing.
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
Clearing big brake calipers. Note splined, open-end, titanium lug bolts. Got these for the Corvette, but was a little nervous to try them, used steel lugs instead. Been on the Jeep for 6 months...no problems & look sharp. Trimmed the ARP wheel studs down a little, dabbed some paint to keep 'em from rusting...
Jeep Wrangler JL The reason for wheel spacers ? BBK
