Texas Wheeling
72Blazer
72Blazer
The Real South Texas
72BlazerCrawler 72Blazer12V 88SBDuramax 18JLUR
SLP
Got some good wheeling in Saturday 11/29. We were in a group of 3 as everyone bailed at the last minute. I got turtled once pretty bad. Had to use the roll cage off a buggy to lift the front end and get tugged out.
Jeep Wrangler JL Texas Wheeling IMG_4818
Jeep Wrangler JL Texas Wheeling IMG_4790
Jeep Wrangler JL Texas Wheeling IMG_4779
Jeep Wrangler JL Texas Wheeling IMG_4783
Jeep Wrangler JL Texas Wheeling IMG_4784
Jeep Wrangler JL Texas Wheeling IMG_4753
Jeep Wrangler JL Texas Wheeling IMG_4781
72Blazer
72Blazer
SLP
Figured my front frame chop has been sitting in the box too long so got to getting the old setup out of the way to make room for the @NextVenture frame chop. I would like to do the 5” but the 3” seems to be more realistic for my overall purpose. Cruised around over the weekend topless before tear down started.
Jeep Wrangler JL Texas Wheeling IMG_5081
I put my steel bumper on my son’s JK so needed to remove the JCR winch plate and winch. Winch was also filthy so pulled the line. In the process, I took the solenoid control box off the winch to figure a relocation plan for it
Jeep Wrangler JL Texas Wheeling IMG_5082
Jeep Wrangler JL Texas Wheeling IMG_5111
Mocked up
Jeep Wrangler JL Texas Wheeling IMG_5085
Main section painted with several coats
Jeep Wrangler JL Texas Wheeling IMG_5129
The relocation of the solenoid took several hours. Mocked up a bracket for the driver side, FAIL. Pulled the passenger @CavFab_mfg inner fender, FAIL. Pulled the air filter box to check for clearance, FAIL. Pulled the battery to figure if I could cut the plastic box to run the battery the opposite direction, FAIL. Contacted @Kbach to see if he ever built custom boxes for the solenoid and appreciate the input he gave me. Finally, I decided to just throw the battery back in and start pulling my grille off to see if I could mount it behind there. As I put the battery back in, I realized I could push the battery over just a tad bit, clearance a bolt on the fender, and this would allow me to wedge the factory warn winch solenoid box in there. The wiring out of the solenoid will clearance just enough to slightly imprint on the hood insulation. Ran to get some wiring and within a few more hours, I had the wiring routed and ready to go once the bumper is finished up. The plan is to knock it all this weekend. The wiring worked good with no issues yet.
Jeep Wrangler JL Texas Wheeling IMG_5127
yeah it’s rough in, don’t hate, my daily is in the shop so gotta keep this one ready to roll out.
Jeep Wrangler JL Texas Wheeling IMG_5128
72Blazer
72Blazer
SLP
Finished up the bumper yesterday. What a pain in the ass. A lot of tedious work. Not sure I’d recommend this over the EVO front frame bumper that seems to be a bolt in. Overall I’m happy with the product and outcome, just definitely a lot more than I anticipated.
@NextVenture front frame 3” chop done. I feel it looks a little incomplete without the hoop, so planning to add it down the road.
Jeep Wrangler JL Texas Wheeling IMG_5232
Jeep Wrangler JL Texas Wheeling IMG_5233
Jeep Wrangler JL Texas Wheeling IMG_5238
Jeep Wrangler JL Texas Wheeling IMG_5240
Jeep Wrangler JL Texas Wheeling IMG_5231
ObiMatt87
2024 Anvil JULR XR, 2018 Mojito Sahara JLU, 2018 Buick Enclave Avenir
Former Air Force/Current Air Force
Looks very solid, but yeah, I can see how that took time. Nice work, though!
72Blazer
72Blazer
SLP
Went looking for pics with my old set up to include a CavFab bumper and steel bumper. I can really see the difference and benefits I’ll be getting not only for four wheeling but also aesthetically.
Jeep Wrangler JL Texas Wheeling 4F49488C-8160-4CE3-8FC5-A274EA035F8E_Original
Jeep Wrangler JL Texas Wheeling IMG_0638_Original
72Blazer
72Blazer
SLP
You can have some of the best parts on your jeep but if that maintenance isn’t up to par, then the slightest issue is really going to mess up your day.
I started having cooling issues Tuesday. Then I noticed I was losing coolant. I limped to a buddy’s house and by the time I got there my Jeep was severely overheating. To top it off, my CEL went haywire and the jeep started misfiring like crazy. I pinpointed the leak to the reservoir tank and the electrical issue either to my winch wiring (which was disconnected via the cut off switch so 🤷🏻‍♂️) or to my fog lamp wiring (which are no longer in place.) I replaced the tank and did a coolant flush and plan to do another. I also had been hearing a whine from the rear end and that ended up needing a quart of fluid. Rerouted my fog lamp wiring to behind the grille and retaped and sealed it. Then disconnected the winch wiring completely. I’ll address this with more time. I guess I should start doing new plugs, coil packs, serpentine belt, etc. I’m already at 156k miles. :giggle:
before and the issue
Jeep Wrangler JL Texas Wheeling IMG_5316
After
Jeep Wrangler JL Texas Wheeling IMG_5317
some Blanton’s for all the hard work.
Jeep Wrangler JL Texas Wheeling IMG_5320
I also had a loose nut on a lower control arm and a missing bolt on the bracket for the lower radiator hoses. :CWL:
72Blazer
72Blazer
SLP
Mall crawler status
Jeep Wrangler JL Texas Wheeling IMG_5352
Had room in the storage and so tucked her away for the week
Jeep Wrangler JL Texas Wheeling IMG_5360
Thinking I’d like to do a K2 or WolfCaves run next month
72Blazer
72Blazer
SLP
I’m planning a trip to Katemcy Rocks for Memorial Day weekend if anyone would like to join. Jeep is currently in the shop again. Coolant leak, service 4wd light, and AC intermittently blowing hot air. :angry:
72Blazer
72Blazer
SLP
AC fixed. Coolant leak fixed. Serv 4wd light remedied for now. Added a spare delete from @DV8Offroad and came across some quality control issues. Not sure id buy from them again but the setup fit what I needed it to do. Thing is ready to boogie for September.
Jeep Wrangler JL Texas Wheeling IMG_8523
ObiMatt87
Looks good! What is the larger canister on the right side? Is that compressed air?
ObiMatt87
All the cool kids say NOSSSSSS.
Yes. Compressed co2
:CWL:
Ah, gotcha! Clearly I was not in the cool kids club. Thanks for including me!
