Tazer turn assist
RubyRecon
Rick
The OC
2020 Rubicon Recon
Has anyone used the TaZer turn assist? I Have programmed the Hot Button but not sure how it work? I haven’t been off road yet.
do you just turn it on and turn the wheel and it Senses which wheel to lock up?
thanks in advance.
JAF1
Pittsburgh, PA
2021 JLUR (RIP)
It works great. First you must be in 4low, then you can turn it on. You'll see "turn assist on" or something like that in the display. It activates only when you are make a hard turn one way or the other. It just locks up one of the rear wheels. You'll hear the ABS working. Try it with and without next time you're off pavement. Much smaller turn radius.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Is the turn assist smart enough to know not to engage when the lockers are engaged?
AZCrawl
AZ
2018 Granite Jeep JLUR
I just started messing with this for the first time tonight, it appears to engage in 4H too. ABS makes a lot of noise but it didn't appear to totally lock the rear wheel. I was turning left and was watching the left rear.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I used it for the first time a couple weeks ago when I saw the Jeep in front of us have to make multiple attempts to turn around. Yeah, it's noisy AF, but it significantly improves the turning radius. My wife was a bit shocked when I was able to turn our rig around in one swoop.
It does, however, chew up the trail. Use it judiciously.
AZCrawl
AZ
Thanks, but does it work in 4H as well as 4L?
