MntGoat
So Tazer is hooked up and I chose my Light show, and scrolled through the menu's
I plan to change a lot of stuff this weekend.
How will the lockers work? Factory switch....Up is front on and then push button down to turn off? Push down to turn rear on and lift up to turn off?
OR
When buttons are assigned to different things how do you toggle between them? I will need quite a few to turn everything on and off?
Just want an idea, so when I try it and read the directions I am familiar with process
I want independent locker activation.
4 wheel brake lock (for winching)
Winch mode, to up idle
Lock front and rear brakes for digs
lock inside rear brake to add tight turns with locker off
That's 7 switches so far
TIA
